Hi All,
As of last night, my 98 Ranger 3.0L 4x4 started blowing thick white smoke out of the tail pipe, a clear sign of a coolant leak somewhere in or around the cylinder. The obvious diagnosis would be a blown headgasket. But I don't have any coolant in my oil, or vice versa. Nor are there any visible coolant leaks or on the ground below.
I tried to take it to the mechanic this morning for a cylinder compression test, as well as a coolant leakdown test. Due to a combination of sickness and vacation, they are understaffed and not able to look at it until next week. This is my daily driver, though, so I can't afford to wait that long. Hoping to tackle the project this weekend if possible.
So, a few questions:
Thanks, in advance, for all your help. I'll check in regularly until this is solved.
1) If I can get my hands on the right tools, will a simple $35 compression tester do the trick? Similarly, will a simple block tester rental tool from autozone or o'reilly be able to accurately diagnose a cooling system leak? In other words, can I trust myself to diagnose or is this better left to a garage?
2) If it is a head gasket, why is there no cross-contamination between coolant and oil? Is it possible that this could be a much simpler intake gasket?
3) If it is just an intake gasket, can I leave the head alone? Or would it be best to replace the whole works right away.
