Big Jim M
Did you prop the throttle wide open for the compression test?
The balloon told ya that you do have a compression leak. Then the compression test PROVED where it is.
Now you pull that head and give it a look. Was it mine I'd be pulling the other also and installing a new gasket there also.
The block surface needs a real good inspection with a good light to make sure it is intact.
So far you haven't indicated anything that would indicate worn out rings.
Get out there and get to it.
Big Jim
Big Jim
