115 hp inline 5. 8 speed shuttle shift, with this neat steering feature. 3 modes: A= 2wd , B= 4wd, C= 4wd plus (when you turn past 20deg the front wheels do 1.5times your ground speed to make your corner
tight. we rarely use this thought) I REALLY want to find the front axle off a 60-90 hp Kabota tractor and put it up front. Insane strong, electric diff lock, and DROP DOWN BEVEL DRIVES = incredible steering angle + incredible clearance! 3-link that out infront of the engine cross member and lets see what I can get throught!! (we have a farm equipment junk yard 1/2 drive away, I have been meaning to go for a stroll!)
Yes, yes it does have Bawlz. I have yet to get it stuck. I have got the big 4wd stuck, but not the Kabota. lol. I am also very happy it didnt get found out there!
Dudes. My hex-to-C'shape is strong.
It's because I bent it that it broke. Perhaps these pics will explain. I used this press to straighten it as mentioned above. The shaft that is flush with the break is the hex shaft that I turned down on the lathe to fit into the c'shape. The stock rad arm only had the 1 strip of weld length wise, I have that, plus a weld around the hex where it steps up to c'shape.
What I added to the rad arm did not break. The ford part broke
because I changed it abit.
See?
