- Oct 18, 2007
- Automatic
I removed the rad arm.
I ground the weld holding the pin (with threads on the end for your rad arm nut to go over the and hold the rubber bushings) and drove the pin out.
I turned down the hex on the latch so it was a mild interference fit.
Welded the straight, then welded around the hex where it steps up to the arm. I did not change the ford arm.
Installed, discovered bad caster, bent on press.
Broke driving through ditch.
I removed a solid pin, I replaced a solid pin. I do not believe I changed the cross sectional area, If you do, might you show me where? So as I dont do it next time?
