- Aug 17, 2011
- Austin, TX
Here's a trick/tip to use. Place the axle under the truck with the arms bolted to the axle but not the frame. Where they rest is where your mounting points need to be...
SVT
No mine turned out almost identical. They were off by 1/4" iirc.
They can be off a little, as long as your length is the same, and your axle is centered correctly (tracbar) your good to go. I can see in your first pic there is bindage...
SVT
