Armadillon's FW Ranger D44/Ford 9"
I was able to grab the correct backing plates from the junkyard and I cleaned them up last night. I had all of the shoes and hardware already, so it was $40 for the plates.
I may do the disc brake conversion in the future, but I want the project to keep rolling along.
and PS, junkyards are so pricey nowadays! Yikes! They wanted $40 bucks for some ancient drums that were attached to the backing plates.
Sometimes it is better to buy new when the scrapyards want next to new prices.
Keep up the good work, starting my SAS soon.
I used that rust converter stuff on the rear axle, welded my perches then made them prettier with grinding. Gloss black paint and then mounted it. I may decide to use a 2" lift block just to get the front and rear a little closer.
My brother gave me some coils off of a B2 (Possibly 6" lift coils?) and it lifted my front even MORE than the coils I had before. On the plus side, they're WAY more flexy.
Still need to:
Plumb rear brakes
Set up parking brake cables (may need to fab a bracket)
Weld on shock tabs and brake line tabs
I ghetto connected the rear driveshaft. I used one of the 1 1/8"x 1 1/6" U joints so the stock shaft would mount to the rear 9. I may have been tired/drunk/poisoned when measuring. I say this because the 1 1/16" end, which fits the Ranger driveshaft, is a bit too long and I couldn't use the E clips. My caps were sticking out about 2mm on each end.
Since my apartment complex hates me already, and they would throw a fit if they saw a truck with no driveshaft connected, I VERY temporarily solved my issue. Tacked the caps like a boss.
Grrr, if it's not one thing it's another.
I had a set of 4 rollers until I get better tires. My back left tire had a destroyed inner lip. I didn't notice for over a year until I actually mounted it on the vehicle.
Found a guy out in round rock who has 2 35x12.5x16s for $25 each. He said they hold air and that's all I care about at the moment. I just want to be able to move the vehicle.
We've decided to find a new place to live so I can't have an immovable vehicle come move-time.
Hey Phil,
How's it coming along?
Many years later, just a final follow-up.
Eventually moved out of Texas and sold the project to a brother's friend. I think he may have just taken all of what I added and put it on something else.
A sad end, but I'll never forget!
