PlumCrazy's OG Build
Both...normally it has good bit of rake, but that load leveled it out.lol The front appears to be higher than normal actually.
Forgot to share this... hauled some more junk home from the old shop this past weekend...its like a truck, but gets 30+mpg
I loaded more on top too, but the bulk of the load was transmissions, diffs, drill press, axles, etc.lol
I see the TK5 in there.:D
Sent from my HTC VLE_U using Tapatalk
Yup. I havent done a thing with it yet besides trip over it for a year.lol
Sent from my XT907 using Tapatalk
I love Christmas.
Nice. You'll be need those soon.
Do you already have the other chromoly inner?
Sent from my HTCONE using Tapatalk
I already have the long side inner chromo.
Im betting that i grenade a r&p next..
All weak links need eliminated. I learned that the hard way.
Speaking of which what do you have for a carrier?
Stock 4.09 carrier. Mini spooled...if anything lets loose inside the axle I will go 4.89 and full spool.lol
Yeah... Get rid of that carrier. My oem carrier was what let loose in mine. Took out a set of Richmond gears, and broke the housing, didn't hurt my shafts though.
If that happens Ill go HP 44 or 60...
You have a low pinion? I broke my low pinion in 5 trips, stripped the ring and pinion, switched to high pinion and it was much better.
I have two chipped teeth and a stock cross pin too.....
Im not to hard on it normally. I let the doubler to its thing.
I have a HP I will sell ya :)
Those new shafts are pretty!
I just asked my wife if she wanted to see your new shafts. I got that look
Sent from my uhhh
I don't think being hard on it is the issue, just driving off road with large tires is what did mine in. The design of a low pinion pushes the ring gear away from the pinion under load. The high pinion is opposite, the ring gear is pulled into the pinion.
If it were me, I wouldn't put more money into a low pinion if you are already planning on it breaking.
Upcoming TRS Events
Featured Ranger Based Vehicle
