PlumCrazy's Build
Oooo. And the motor needs to moved up or the crossmember needs notched.
Sent from my XT907 using Tapatalk
And take some boost...
These guys showed up today...
Bolted up the blower and upper plenum to the lower intake to check clearances for the temp sender I need to add for the temp gauge and e fan. There is way more room than I thought.lol
I did find out that the phenolic spacer is a must to get the BBK plenum to clear the fuel rail.
The shelf is beginning too seem a bit small....
Apparently my phone was posting from my pocket... Lol.
I need to visit this thing.
After I get all my streetable vehicles running...
a few goodies showed up today...
-New Comp Cam 422
-upper and lower pan gaskets
-updated lower intake gasket set
-Valve cover gaskets
-bolts for mounting BBK plenum
-valve stem seals
-Water pump
-thermostat housing
-rear main seal
-cam bearings
-New Saginaw pump
I also had what was supposed to be a freeze plug set, but it wasnt right, so it went back.
Forgot to share this... hauled some more junk home from the old shop this past weekend...its like a truck, but gets 30+mpg
I loaded more on top too, but the bulk of the load was transmissions, diffs, drill press, axles, etc.lol
