which ball joint do I get?
wrangler8
10+ Year Member
I have a 93 ranger, 4x4, xlt and I need to replace lower passenger side ball joint. however I have a dana 28/35 hybrid front axle. I dont know wether I need to get a ball joint for dana 35 or 28.
35 housing 28 guts. Id go with 35s. And get good ones. Top and bottom...
With the exception of the housing for the gears, the inner axle shafts, and the guts inside the front pumpkin, it is a D-35 in all respects. Even the U-joints for the axle shafts are the same as a D-35. So you will need D-35 ball joints. Brakes, U-joints, bearings, spindles, ball joints, etc are all D-35.
I feel like this is a topic that has been covered to great extent.
Ok thanks everybody.
