Project Double R...
Driver side! Boom! :D
Just have to tweak a couple bolt holes!
let me know how much and where to send the money
awesome stang....i'm gonna have to get me a set of those coil buckets once we buy our house and i can start working on the b2 more. my front shocks are short and use the stud version, plus i dont like my upper TB mount
Give me another week to get it all dialed in and I will let you know. Will you want arms and everything?
pm me what all parts your going to offer and i will let you know what i need
So the driver side bucket has a built in trac bar mount it looks like?
Correct. Should make life easier for a lot of guys.
Do you think it is strong enough? I have seen a lot of guys tear theirs off etc. and had to add a lot of bracing to it
Most of the guys I seen tear there's off applied it to weak metal. Double R, TNT, 2.0, Bronco BIIue, Southern Cut, and other Ranger I built all have there TB mount in the exact same place all attached to the factory coil bucket. No one has an issue. This one is as strong if not stronger. I have had a little practice with this. ;)
Sign me up!! and count me in for one! Let me know where to send the money...
PM me what all parts your going to offer and I will let you know what I need. This is going to be so nice and take out all the guess work. Not only that I have been skeptical on doing the sas due to trackbar mount ripping off, but if you have had experience with it, and the pictures suggest you do, then this was an easy decision.
Only one hole was off!
Pass side bucket...
Clearancing the crossmember for the front shaft...
All bolted in. Just have to drill a few new holes for the added supports.
Transmission mount holes...
I'm liking this...
Event Coverage
TRS Merch
