Southernfarmer
- Aug 18, 2013
I have an 85 ranger 2wd with the 2.3L in it and I've been having problems with it for awhile. It was running good and then all of a sudden it started spitting and sputter, so I changed the plugs, wires with motorcraft, and replaced the IAC, it ran good for a day or two and started acting up again, when I come to a stop I gotta hold my foot on the gas just a hair to keep it from wanting to cut off, when I let off the gas it starts sputtering and the oil light flashes on and off. The other day it just cut off on me at the store and wouldn't start, after an hour it started on to cut off 40ft further, after 45 mins it finally started and I made it 1/4 mile down the road and it cut off and I couldn't get it started and had to get it pulled home. I replaced the fuel filter thinking maybe it was clogged but it wasn't, I got it started and it cut off a few driveways down. I pulled the wire on the coil pack off and it had a blue arc to it I was wondering what this meant. Is my coil pack bad or injectors clogged? I have tried several different things to try to make it run better, injectors cleaners, seafoam, and they haven't done nothing. Usually when you start it up the rpms keep going up and down constantly. I'm stumped anybody have any ideas?
