The wiring is the part that worries me the most. I'm good at it, it's just making sure I know what everything does and I put it in the correct spot...
ROFL. You think I know where all this stuff goes or what it does? I'm guessing at least half of it. I'm just going slowly and testing things carefully. This time.
Got the turn signals and wipers wired in. Have you tackled the cluster yet? I cannot even understand the 1st gen wire schmatics, it looks like scribles connecting. I got the 89 no problem Though.
I do have the cluster wired up. I am not sure of a lot of it though.
I know my lights work, the CEL works, and the tach should work, but it was funny before. I fed power and ground to one set of pins and the temp and fuel gauge both came up to full, so I have no idea what they will do when I plug it in and turn it on, but I can't test that yet. I have some other wires to hook up before I can do that.
The cluster was the worst part so far. A lot of time sitting with a meter and test leads finding where the circuits go and then testing it to make sure I was right. I still don't know I was right on a lot of it, and won't until I put it all back together. That is why I have a second cluster I'm using as a guinea pig.
The problem is that there is no pin-outs for the gen 1 cluster. None that I have found yet anyway. Once I know for sure that my cluster wiring is correct and that the whole thing is working correctly I will post up the wiring for the cluster.
The great part of wiring the cluster from new to old is that actual pins are the same between the two sets of connectors, so there is no splicing. Just pull and plug.
