- Aug 8, 2026
- LEES SUMMIT
- State - Country
- MS - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0L
- Automatic
Hello everyone, I'm posting today asking for some help diagnoising an issue and maybe just general advice on what my next moves should be considering things like cost, time, my level of proficiency, etc.
Vehicle: 2011 Ford Ranger XLT 4.0L 4x4 3.73 axle ratio 8.8" Axle w rear Disc Brakes
The issue: lot's of play in the rear differential and a clanking noise while driving
For starts, the truck doesn't have the manufacturer sticker in the driver door jam like it should so hopefully everything is identified correctly. Instead it has a sticker about tire pressure levels so there are no axle codes. There also isn't an axle tag on the rear diff.
I bought this truck in November 2022 and have always had lots of play in the drivetrain I noticed. When put in drive, there's a noticeable delay before I get that positive engagement. There's also tons of back and forth movement when just pushing the truck by hand when in park compared to other vehicles I've owned. I'm a lazy bad car owner though I'll admit so I've never investigated it further but I assumed wear in the rear diff. Recently, I started noticing a clanking noise that I assume is from the rear diff. I'm a single guy working full time though living in MO away from my home state of FL with not many friends so it's hard to get a good hand to help me diagnose noise things so I've kind of just put it off like usual. Well I finally got to looking into it because it got worse and the first thing I noticed was the pinion seal is leaking bad. I had just looked under the truck a couple of months ago maybe and didn't notice gear oil on the rear diff cover like that so I'm assuming that's more recent. So I popped off the rear diff cover fully expecting to see broken teeth on some of the gears in there but I didn't. I also didn't see any excessive metal bits or shaving in the dirty gear oil or on the filler plug when I filled it back up. I took a video of me pushing on the driver rear tire with the diff open to see the teeth engagement of the gears hoping I could positively identify where the play is coming from but I'm not 100% certain. It seems to be from the spider gears. But I'm not proficient in these things and am unsure. Also, even if it is, I don't know if that would be a sympton of another problem such as bad bearings somewhere else. Idk. I'm ignorant in this so that's why I'm reaching out. As far as my level of mechanical proficiency, I've swapped an entire axle before on a 96' Jimmy, swapped a bent axle later on on that same Jimmy, replaced rear axle shaft bearings on a 97' Blazer, and things of that nature. Nothing involving super precise measurements though. Basically just swapping parts one for one. But I do have some mechanical experience and tools to do some axle work. The rear pinion seal is very cheap and the spider gear set is relatively cheap for me. I know if I take it to a shop, not only will I be out of a truck for a while, it's probably gonna be like 5x the cost of just me buying the parts and doing it myself. But if it's something more concerning or more involved based on y'alls opinions, then I will happily take it to a shop and pay for the service. It's not the best video because of the headlamp plus phone lighting but take a look and tell me what you think. The videos are too large to upload directly so I've posted links. Thanks for your time.
This video shows the clanking and teeth moving
Doesn't show much, just looking around for broken/worn gears
