door seals
jerkyboyxiii
5+ Year Member
nebraska
2001 FFR driver's floor gets wet when going through the carwash. I adjusted the latch that is mounted on the forward edge of the driver's suicide door and got a tighter fit, I have new exterior window sweeps, and I would like to replace the driver's n passenger's door seals. All I can locate is universal stuff. Is there a company that makes seals specifically for our trucks?
You are just guessing. What I would do is pull the trim and then the carpet up and then get someone with a waterhose and experiment where the water is coming from.
What will really ruin your day is when you find out the water is coming from the metal behind the kickpanel when you spray into the grille at the windshield wipers. If you have a external antenna, it may be coming in around the antenna wire seal. Or it may be the windshield leaking and running down the firewall where you can't see it. Too many possibilities to just guess by replacing door seals.
I have not been able to find aftermarket door seals for the 4 door cab trucks, and I have not been able to find NOS Ford seals either. What I did was to buy a universal adhesive-backed rubber tube about 1/4" x 1/2" and put that on the door where it should be contacting the factory seal. This requires a pretty firm slam to get the door closed, but it quieted down the wind noise pretty significantly. I would expect it to help your water leak also.
