Rangebe...version 2.0
IMO any MIG is easy to use. Once you get comfortable on one it doesn't take much to get used to another.
I personally have a Lincoln 170 and 175 Plus, they are 220v, but use the smaller 120v style gun which I love.
-PlumCrazy
I have heard good things about Miller, Lincoln, and Hobart. Hobart seemed the most reasonably priced.
The only MIG I have used was an older Lincoln 220V. My buddies dad always had the settings adjusted for me when I used it. I know it had 5 adjustable parameters and that seemed too complicated for a beginner. Anyway, I also realized that is too big for anything I'd need to do, so for now a 120 will suffice.
Thanks for the input guys, I'll take any more advice if you have it.
Hey boys, sorry was busy all yesterday.
Brinker I will disagree with you...I loved my Hobart 135, but it was not powerful enough. I know you say you can weld 1/4 with a single pass, but I assure you that you are NOT getting the penetration that you want. When I welded 1/4 with my 135, I would pre-heat the metal to try and get better penetration. I put probably 50 spools of wire through that thing, I know what it can and cannot do. That is why I stepped up to the 190. You cant get enough heat out of a welder that runs on 110V.
In my opinion, go straight to the 190. It has nothing to do with building hardcore stuff, as it is cost. Had I known what I do now, I would have went straight to the 190 and skipped the 135. However if what you can afford for now is a 140, do it. Dont even bother with the 125. As far as Im concerned, Hobart makes a great welder and have awesome technical/customer support.
A little big for your needs, but I use a Miller 212. I absolutely love Millers, and they have a feature on some of their machines called "Auto-Set" which is very nice for beginners! The 212 I have has the auto-set. I tried it out a couple times, neat feature and would be great for a new welder! I know some of their smaller machines have this feature as well, maybe something to keep your eye out for!
I have my eye set on a new Miller 211 here sometime in the near future
Thanks for all the help! The Millers look very nice, but may be a bit out of the price range.
On another note, what advantage do you gain with a spool gun?
Spool guns are great for aluminum work. They pull the wire instead of push it.
aka REQUIRED for aluminum work. Aluminum is too soft to try and run through the liner of a whip. Hence why the spool gun is used.
New cam bearings in, new freeze plugs in. Got block, main caps, crank, cam all nice and clean. Checked tolerances with plasti-gage, all is within spec. Installed cam, crank, and timing set. Spins really smooth.
Shortblock. waiting on my Ford Racing oil pan to show up from summit.
:icon_surprised:
looks like you've gained an extra 4 cylinders since the last time I checked this thread.
Badass!:icon_cheers:
New oil pump and Ford Racing oil pan and pickup. Rebuilt the heads, and gave them a mild port job as well as lower intake.
