- Oct 14, 2010
- Williamsport, Pa
^ This plus you need to drill/cut some 2" holes in the steel and weld them up as well.
Looks good, but where you plated the frame instead of a straight vertical weld you should have fishplated it. Right now the straight weld from top to bottom is now your weak point in the frame...
SVT
it's not in a rollover that the mount points matter...it is in a front/rear collision where your torso moves front to rear....as you move forward the lower mounting point will compress your spine causing vertibral fractures....
l8r, John
Trucks looking good, didnt realize you had an HO 302 in there as well. Keep it up.
