Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
Well, the m5od-r2 takes a 164 tooth flywheel. Since my engine is from 1980, i would want to use a 28 oz flywheel. Correct? I just need to make sure the harmonic balancer is a 28 oz one as well. How can i tell?
I think my friend might have put a different accessory drive on, but i don't know if he changed the harm balancer. I wish i could contact him
I found this one on summit
http://www.summitracing.com/parts/ZZZ-50-735/
It should be a 28oz balance, this might help.
http://www.mustangandfords.com/techarticles/28738_ford_basics/photo_03.html
The tranny won't care what balance the engine is, it just keeps the engine from rattling itself apart and the tranny should feel zero balance.
If its a 1980 then go to the parts store and tell them you need a harm bal and a flywheel for a 1980 F-150 that had a 5 Spd. Make sure it is the 164 tooth and you'll be set! Then get the clutch too or do you already have that? It should be a 11" clutch.
I highly doubt many 1980 F-150's had 5 speeds. A four speed flywheel "should" work. If the flywheel you already have lines up with the tooth count it would probably work too. The T-5 wasn't available in the Mustang until '83 so somebody has already done some mixing and matching.
