Looked up your build thread and it was great. The DOHC sure takes up more real estate then the SOHC. I'm almost done the wiring, check, check and double check, just need to tidy it up. What did you do with your fuel system. I have the 4.6 pump but it's a single line set up. The pcm looks at all the fuel line stuff, is that a problem down the road?
It's good to be able to talk with someone who has been through it already and has worked out some of the bugs.
Thanks
Ron
I used the original tank and modified the sending unit to fit the Mark VIII pump. My plans are to upgrade that pump this winter to a Walbro.
I attached a fitting to the sender assy. also ran a return line up to the engine.
