Kyle M's Ranger Rebuild
looks good. what gear ratio you going to be running in the diffs? and what tranny you mating to the 302?
that's the coolest H2's ive ever seen!
i got some catching up to do!
Ordered my shifter, went with the Art Carr/Winters shifter, should be sweet.
Got my oil filter relocator kit today, but it isn't the right one......damn
Then I realized I need to find some manifolds to put on my 5.0 if I want to have exhaust. Anybody have a set of cast manifolds layin around?
I set the motor down on the frame, but need to remove the headers and modify the heater box before I can bolt it in.
Ready to get moving on this thing.
I've heard they don't work on some applications, but I've got a set of 89500's if that'll help...
SVT
Motor mounts made, engine sitting in its place, soon to be for good
Sitting nice and low. I used the factory 4.0 mounts and made some adaptor plates.
Now to get a radiator that fits or make what I have work.
Kyle, does your motor sit level with the 4.0 mounts and flat plates?? For some reason my motor sits high on the passenger side...I never have fixed it yet....Guess I need to make some plates for mine (I used the explorer plates and ranger mounts)...
SVT
It did, It was about and inch higher. I re drilled the frame and lowered it so they both sat level then made my plates to match.
You're such a good worker.... When I grow up can I be like you?
You should change your group membership from 1/2 ton SAS to 1 ton sas, that way people know just how cool you really is.
Event Coverage
TRS Merch
