Gt-12
Don't forget the proprietary metric left hand screwdriver he'll need to install it...
i think tom would already have one... being he lives in canada...
actually, irwin now makes metric and SAE crescent wrenches, straight up, no joke
hopefully...
hey though, Tom, i found a cheap solution for your radiator problem, see if you can get your money back from the rad shop... this is only $199 and should do the trick...
http://kalecoauto.com/index.php?mai...oducts_id=35&zenid=h2d1t6qe9ktobb7blse5li3ab5
ummm....nope.
that thing is made to hold heat in,i need to get heat out.
that's simply one of those things where they are trying to scam money out of people that don't know how things work,like the electric turbocharger.
they also sell cross drilled brake lines, to help you stop... and heavy duty tire beads to keep yours from popping when you air down or take a hard corner...
http://kalecoauto.com/index.php?mai...roducts_id=1&zenid=h2d1t6qe9ktobb7blse5li3ab5
they also have flux capicitors, the newer models that are not vehicle spesific like the older ones...
and yes, i know they are all jokes, you can't actually order anything from the site, i tried, just to see what would happen
I thought the wiper blade sharpener is ingenious idea...
Hahaha.
Sent from my HTC using Tapatalk
ah,i never looked that hard to see it was a joke site.
i guess the joke's on me:icon_twisted:
lol!
it's a really well done site, but yeah, they are all products people tell idiots they need for their car...
butt dyno, muffler bearing, sky hook, seasonal tire air (winter, spring, summer and fall varieties) blinker fluid...
Yeah, someone spent a lot of time on it.
lol!
i'll have to take a closer look when i've got a minute...in the mean time,i've got the throttle linkage completed.
it looks so cool in operation(if you're as in to that sort of stuff as i am)i figured a photo wasn't enough,so....
Gt-12
i took a short vid.
it works super smooth,even better than what i expected.there's 8 ball joints in the linkage.
Gt-12
i took a short vid.
That's so sweet.
Well done sir! Not nearly as awesome as the burnout vid we are all waiting on, but well done.
burnouts will be a lot easier with a functioning throttle:D
so of the four key controls i need to make this thing move under it's own power,i have:
steering
shifter
throttle.
that leaves brakes,and all i need for that is to run one brake line and bleed it.
and i guess a driveshaft would be a good idea,too.
If you would have just gone the jet engine route like i said you wouldn't need a driveshaft....
that linkage is very awesometastic Tom!
Upcoming TRS Events
