Wow, lots of hits on this thread overnight.....
Splitting the insert would have been cheaper.....
I thought about that, but at that point the Heim was done for anyway, so what the heck
...One that would be a step between a 4wd ranger and a mostly flat F150 arm would be a 2wd ranger pitman arm, they're around a 1" drop.
Thanks, I'll look into picking one up.
i would prefer to run a flatter arm with a 1 ton tie rod end in the normal low side of the pitman arm at the box. certain year 250 arms will be perfect with a lil more throw to boot...
Thanks I'll Look into that option as well.
...using a bolt always ends up janky in the end on most rigs i see out in the world....
I don't disagree and I'm sure the bolts will go away in the future. Unfortuatenly, all the high steer arms, and the knuckles were allready drilled out to 3/4" prior to me owning this 44. So I'm kinda stuck with what I've got at this point. If I wind up blowing the 44 apart on a regular basis, I'll fix the steering when I go 60. I'm hoping the Hydro will help with the "Janky" feeling some.
If your using heims for 'strength' over a TRE, you may wanna click
THIS link and check out Evolution Machines TRE's... they are the cat's ass.
Yikes! Those are pretty dang pricey! But as stated before, I'm using the Heims since that's what the holes were allready drilled out for.
also looks like you bought 3/4" heim joints. 3/4" shank 5/8" ball is the joint that size you want for steering.
5/8" would have worked, but as I noted before, the PO had allready drilled it out to 3/4". Work with what you got I suppose.
more i look at the bed, i'm thinking the bob should have been the rear section, not the front- that would have helped w/ departure angle..
but that's your choice. nice truck none the less.
has to have the stock bed length after the axle cause of the leaf springs......
if he were to link the rear, then he could bob after the axle.....but keeping leaves is way more simple....
l8r, John
Yup, I'd have to link the rear to get the bed shorter, but I still need this thing to "be a truck" on occasion so I don't really want to shorten the bed further than it allready is. The departure angle allready beats the pants off of my XJ, and to be honest, there isn't that many ledges to climb out in the midwest anyway.
Those Evo TRE's are wicked. I was going to pick me up some of those, but a normal 1 ton Chev TRE should suffice.
I've got a feeling that I'll wind up with the chevy's at some point in the future if for no other reason than you can find them at any parts store.
Thanks for the comments guys!
