Axle Swapping – In The Beginning:
There was a time not that long ago that Ford Ranger & Ford Bronco II owners were trying to figure out how to swap in Dana 44 solid front axles and were swapping Ford 9-inch and 8.8-inch axles into the rear. The goal was to add stronger axles for bigger tires. There were initial concerns about narrowing axles to fit under these vehicles, so for many, the hunt was on for the early Bronco axles and the Explorer 8.8’s.
But as offroaders became more extreme with their rigs, they looked for even more extreme axles. They moved on from the Dana 44 and 9-inch axles and began hunting down Dana 60 front and rears. But with rigs being built more and more to be able to handle rock crawling, enthusiasts found the limitations of the Dana 60 and began looking for even larger axles.
The GM 10.5 (14-Bolt) full-floating axle is quickly taking over in popularity. They’re a very strong axle and can be picked up pretty cheaply. They’re not the only beefier option to the Dana 60 though. This article is to give you some information on the most common heavy duty full-floating axles being discussed today.
What Is A Full Floater?
Full Floating Rear Ends
(Full floating axles are quickly identified by the hub bolts at the end of the axle)
A full-floating axle can be identified by a protruding hub to which the axle shaft flange is bolted. These axles are able to carry more weight than a semi-floating or non-floating axle assembly because the hubs have two bearings riding on a fixed spindle. The axle shafts themselves do not carry any weight; they serve only to transmit torque from the differential to the wheels. Full-floating axle shafts are retained by the aforementioned flange bolted to the hub, while the hub and bearings are retained on the spindle by a large nut.
A nice feature about a full floating axle is that the axle shaft and wheel won’t come out of the axle if the shaft breaks, and you can remove the axle shaft without removing the wheel.
Full Floating Rear Ends - Exploded Parts View
Above is an exploded view of a full floating axle.
Below is an exploded view of a non floating axle.
Full Floating Rear Ends - Non-Floating Exploded Parts View
(Non floating axle above)
Full Floating Rear Ends - Axle Shaft Retaining Bolts
Full Floating Rear Ends - Pulling the axle shaft
Full Floating Rear Axles
Dana 60 Dana 70 GM 14-Bolt (10.5) Sterling 10.25 / 10.50
Ring Gear Diameter 9.75″ 10.5″ 10.5″ 10.25″ / 10.50″
Pinion Shaft Diameter / Spline 1.625 / 10 (early)
1.625 / 29 (late)
1.75 / 10 (early)
1.75 / 29 (late)
1.750 / 30 1.940 / 31
Axle Shaft Spline / Diameter 16 / 1.31″ (early)
30 / 1.31″ (late)
23 / 1.5″ (early)
35 / 1.5″ (late)
30 / 1.5″ 35 / 1.5
Tube Diameter 3.125″ 3.562″ 3.48″ 3.50″
Tube Thickness 0.25″ – 0.56″ 0.31″ – 0.47″ 0.21″ – 0.49″ 0.44″
Weighs 260 pounds 270 pounds 450 Pounds
(without brakes)
550 pounds
(with brakes)
310 pounds
(single wheel)
330 pounds
(dual wheel)
Housing Grey Iron (early) Ductile Iron (late) Cast Iron (early) Ductile Iron (late) Grey iron Nodular Iron
Max Output Torque Rating (Short Durations) 5,500 lbs-ft 8,000 lbs-ft
8,800 lbs-ft (D70HD)
6,242 lbs-ft 8,300 lbs-ft
10,660 lbs-ft
Gross Axle Weight Rating (GAWR) 6,000-6,500 lbs 7,500 lbs 10,000 lbs (D70HD) 5700-8600 lbs 6250-8250 lbs
Max Tire Diameter Rating 38-Inches 44-Inches 44-Inches 40-Inches
44-Inches
Found In 1955-1985 Ford F-250
1974-1985 F-350 4×2
1968-1972 Chevy K20,
K25
1973-1978 G-300 van
had 35-spline full floats.
1979-1980 Ford F-350 Dually
1957-1980 Dodge W-300
1981-1993 Dodge W-350
1957-1993 Dodge D-300
D-350
1994-2002 Dodge D250
0 & W2500
1979-1986 GM C-30
& K-30 (mostly dually)
1987-1991 R/V-30
(dually)
1973-2001 Chevy K-20,
V20, K30, V30, K2500,
V3500, K3500 Pick up
and some Suburbans
2001-Up Chevy K2500
1973-2001 GMC K2500,
K3500
1985-1999 F250HD
& F350
Replaced the Dana 60
and 70 1999 & up
have the 10.50 axle
Max Gearing 7.17’s 7.17’s 5.13’s 4.30
Miscellaneous Dana 60 & Dana 70 use the same differential covers. Dana 60 & Dana 70
use the same
Pinion support bearing. 10.5 has a straddle
mounted pinion
(three sets of pinion
bearing) and a 4 spider
diff in stock open form.
Dana 60 & 70:
Full Floating Dana 60
Dana 60
Full Floating Dana 70
Dana 70
The Dana 60 and 70 are very similar in appearance. In fact, the differential covers will interchange between them. You can tell the Dana 70 from the Dana 60 because the housing sticks out past the cover.
GM 14 Bolt:
GM 10.5 AKA GM 14-Bolt
(GM 10.5 AKA GM 14-Bolt)
You can see how tall and thick this housing is. A common upgrade is to shave the bottom and weld on a plate to close it back up to allow more axle clearance.
Ford Sterling 10.25:
Ford 10.25. Note the ribbing around the edges
Ford 10.25. Note the ribbing around the edges.
Comparisons:
GM 14 Bolt Differential Left vs Dana 60 Differential Right
GM 14 Bolt Left – Dana 60 Right
Dana 60 axle vs GM 14-bolt axle
Dana 60 Left – GM 14 Bolt Right
You can see that the GM 14-Bolt axle shafts are larger than Dana 60 axle shafts
Dana 60 Top – GM 14 Bolt Bottom
Dana 60 ring gear left - Dana 70 right
Dana 60 ring gear left – Dana 70 right
About The Author
