Introduction
This article discusses the automatic transmissions that were offered in the Ford Ranger from 1983-2011.
Transmission Code
This article refers to ‘Transmission Codes’. You can find the transmission code by checking the Ford federal sticker on the driver’s door jamb. The code will be on the bottom row under ‘TRANS’. See ‘(3)’ in the image below.
Transmission Model / Trans Code Chart
| Model | Trans Code | Vehicle | Speed | Ratios |
| C3 | V | 1983-1984 2WD Ranger | 3-Speed | 1st: 2.47
2nd: 1.47 3rd: 1.00 |
| C5 | W | 1983-1984 4WD Ranger | 3-Speed | 1st: 2.46
2nd: 1.46 3rd: 1.00 |
| A4LD | T | 1985-1994 Ranger With Overdrive | 4-Speed | 1st: 2.47
2nd: 1.47 3rd: 1.00 4th: 0.75 Reverse: 2.10 |
| 4R44E | T | 1995-2000 4-Cylinder & 3.0L Rangers | 4-Speed | 1st: 2.47
2nd: 1.47 3rd: 1.00 4th: 0.75 |
| 4R55E | T | 1995-1997 4.0L Rangers | 4-Speed | 1st: 2.47
| 5R44E | D | 2001-2009 w/2.3L & 3.0L | 5-Speed | 1st: 2.47 2nd: 1.86 3rd: 1.47 4th: 1.00 5th: 0.75 Reverse: 2.10 |
| 5R55E | D | 1998-2011 4.0L Rangers | 5-Speed | 1st: 2.47
2nd: 1.87 3rd: 1.47 4th: 1.00 5th: 0.75 |
| 5R55W | R | 2002-2011 ford Ranger 4.0L (2002-2010 Ford Explorer) | 1st = 3.22
2nd = 2.41 3rd = 1.55 4th = 1.00 5th = 0 .75 Reverse = 3.07 |
Descriptions:
C3 – The Ford C3 is a light duty 3-speed automatic transmission that was available in the 1983-1984 2WD Ford Ranger. This transmission was replaced by the A4LD in 1985. The C3 is a weak transmission that was only intended for light duty 4-cylinder applications, and small V6’s. Because of it’s light duty, it was not used in 4×4 applications.
C5 – The C5 is essentially a C4, but with a lock-up clutch in the torque converter to improve highway fuel economy. The C5 was used in the 1983-1985 4X4 Ford Ranger. The C5 is a good transmission, and was the only automatic used in a 4×4 Ford Ranger that wasn’t computer controlled.
A4LD – The C3 was modified into the A4LD 4-speed automatic by adding an overdrive gear, which the C3 lacked. This was the first Ford automatic to use an EEC-controlled torque converter lock-up clutch. Electronic shift control for the 3–4 shift was later added, another first, though other gears remained hydraulic. It was replaced by the 4R44E and 4R55E in 1995. The A4LD is a weak transmission and is known to fail in offroading (4×4) applications.
4R44E / 4R55E – The name 4R44E means 4 forward gears, rear-drive platform (or 4WD, with a different tailshaft housing), rated for 440 ft/lb torque (after torque converter multiplication) and electronic shifting. 4R55E is the same but heavier duty and rated for 550 ft·lbs.
For the 1995 model year, the A4LD was upgraded to feature full electronic controls, resulting in a new transmission family. The two major versions of this new transmission were the 4R44E and 4R55E. The transmissions are fundamentally similar in design, varying only in the durability of key components based on the type of duty they were to be used for.
The 4R44E was used in lighter-duty applications, namely with 4-cylinder or 3.0 L V6 models of the Ford Ranger pickup.
The 4R55E was used in heavier-duty applications, specifically with the 4.0 L Cologne V6 used in vehicles like the said Ford Ranger or Ford Explorer.
The 4R55E was short-lived however as it was replaced in all instances where it was used with the newer 5R55E during the 1997 model year. The 4R44E continued on through the end of the 1990’s before being replaced by the 5R44E (5R55E’s relative).
5R44E – Like the 4R44E relative to the 4R55E, a version of the 5R55E was made for lighter duty applications: the 5R44E. An example of these transmissions used in a single vehicle line would be in recent versions of the Ford Ranger pickup where the lighter-duty 5R44E is mated to a 3.0L Vulcan OHV V6 while the heavier duty 5R55E is mated to the more powerful 4.0 L Cologne SOHC V6.
5R55E – The 5R55E, though mechanically identical to the 4-speed 4R55E, was a five-speed transmission, the first produced by an American maker. The ability to produce five forward gears is by improved software control. The 5R55E introduced adaptive shift control and sophisticated friction to friction shift ability. The 5R55E introduced Directional high energy frictions and eliminated all but one thrust washer with high-capacity thrust bearings. It was the first 5-speed electronically controlled transmission in an American vehicle. It was designed for the high-torque 4.0 L SOHC and 4.0 L OHV Cologne SOHC V6.
5R55W – Following the original “E” series of the transmission introduced in the 1998 model year, other variants of the 5R55 transmission appeared. All variants are fundamentally similar to each other in design but differ in things such as specialized controls, gear ratios, or other elements based on the needs of the specific application the transmission is intended for. The 5R55W began use in November 2000 for the 2001 Ford Ranger.
I find mixed information on this. Some resources state that the 5R55W only came in the Ford Explorer from 2002 to 2010, and was not available in the Ford Ranger.
Bellhousing Information:
The SOHC and OHV use very similar bolt patterns. The only difference is the top right bolt (as viewed from the rear) was moved down and to the right by about 2-inches. The rest of the bolts line up. This bolt was moved for clearance for one of the SOHC timing chains. Looking into the transmission, it would be the top left bolt being moved down and to the left. A 5R55E automatic transmission bellhousing has the holes to mount to both the 4.0 OHV and 4.0 SOHC.
The 4r (4R44E / 4R55E / A4LD) transmission bellhousings have a larger starter pocket than the 5R transmissions (see photo above).
The 3.0L Bellhousing has a wider bolt spacing at the top and is angled. It also uses a 3-bolt starter. The 4.0L bellhousing has a narrower bolt pattern at the top and uses a 2-bolt starter.
The 4.0L & 3.0L engines have the starter mounted on the driver’s side. The 2.0L, 2.3L, and 2.5L engines have the starter mounted on the passenger side.
The Ford 2.8L, 2.9L, and 4.0L Cologne engines share the same ‘Taunus’ bellhousing bolt pattern.
The Ford 3.0L uses a different ‘Vulcan’ V6 bellhousing bolt pattern.
The Ford 2.0L, 2.3L and 2.5L Lima engines use the ‘Lima’ bellhousing bolt pattern.
The Ford 2.3L Duratec uses a ‘Duratec’ bellhousing bolt pattern.
Visual Identification (Pan Bolts):
Visual Identification (Photos):
C3 Automatic Transmission:
(Click the photos to enlarge)
C5 Automatic Transmission:
The C5 automatic will have a hump in the bottom of the transmission pan. Note how the one shown has a smoother bellhousing than the one on the engine stand. The C5 on the engine stand has a V8 bellhousing. You can see it’s ribbed for more support. The other photo is of a C5 from a Ford Ranger that someone added a transfer case doubler to.
A4LD Automatic Transmission:
4R44E / 4R55E Automatic Transmission:
5R44E / 5R55E Automatic Transmission:
5R55W Automatic Transmission:
Related Articles
Ford Ranger Fluids & Capacities
Ford 4R44E / 4R55E / 5R55E Valve Body Gasket
Replacing A Ford 4R55E with a 5R55E
7-Common Problems With The Ford 4R55E Transmission
Automatic Transmission Fluid Change
Put A GM 700R4 Behind Your Ford 4.0L V6
Installing a Torque Converter lock up switch
Adjust / Repair Instrument Cluster Gear Indicator
A4LD Pressure Switch For Lock Up Torque Converter
AllanD’s Transmission & Transfer Case Guide
Automatic Transmission Troubleshooting
Last Updated:
About The Author
Jim Oaks is the founder of The Ranger Station, one of the longest-running Ford Ranger enthusiast communities on the web. He has spent over three decades owning, modifying, repairing, and driving Ford Rangers on the street, trail, and cross-country routes.
Since launching TheRangerStation.com in 1999, Jim has documented thousands of real-world Ranger builds, technical repairs, drivetrain swaps, suspension modifications, and off-road tests contributed by owners worldwide. His work has been referenced by enthusiasts, mechanics, and off-road builders looking for practical, experience-based information rather than theoretical advice.
Jim’s hands-on experience includes long-distance overland travel, trail use, drivetrain and axle upgrades, suspension tuning, and platform comparisons across multiple Ranger generations. The content published on The Ranger Station is grounded in first-hand experience and community-verified data, not marketing claims or generic specifications.
