Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-06-2010, 09:34 PM   #1
Lift
Lift's Avatar
Vehicle Year: 1983
Vehicle Make: Ford Ranger
I use this vehicle for: My Senior Project
Lift is on a distinguished road
Default IDLE Air Control valve
Ok ok i been on this problem for a while now i just finally took the time to figure it out. Heres the problem: Start it up hot or cold or normal w/e my truck idles at 1800 to 2000. Then lowers to about 1600 slowly. Also it bogs every 45 seconds like goes down and goes back up. So This is what i did. I checked my c02 censor it was good i even cleaned it. That didnt do crap. ok So then someone told me Oh hey you dont have a barometric pressure sensor. Didnt get one yet but i will. Im sure thats not the problem tho but it will help. so I thought maybe it might be my TPS so replaced it. unplugged it while the engine was running and plugged it back in. Boom 1100 rpms But Trun off the engine and turn it back on back to 1600. Hmm so then i thought of this funny idea hey lets unplug the idle air control sensor with the motor on Whala 550 rpms-600rpms doesnt bog down up and down anymore. But if you unplug it while it bogs it kills it or it will keep bogging. I beliave my IAC is Bad Im really excited i think i got it please tell me if im correct. Im really hoping i am. If i am i willl replace it asap! haha
Maybe i will post a video of it running and me unplugging the IAC. But not tell tommorow its dark.
Lift is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-06-2010, 10:53 PM   #2
Lift
Lift's Avatar
Vehicle Year: 1983
Default
anyone?
Old 12-07-2010, 08:24 AM   #3
TrexMex
TrexMex's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger 4X4
TrexMex has a spectacular aura aboutTrexMex has a spectacular aura about
Send a message via MSN to TrexMex
Default
Dude you're describing the exact same problem I had a year ago. Truck was going up and down in revs when idling. I first tried just to clean up the IAC valve and that worked for a couple of days and back to the problem again. I ended up replacing the sucker and 1 year later I'm a happy idler
ALSO, clean up your MAF sensor really good because the high revs are usually indication of a dirty/faulty MAFsensor. There is an article in the Tech Library on how to do it.
__________________
My build thread
Ford Dealership Parts Counter sign: "If the part you purchased was not the one needed to fix your problem, You have a new spare!"
TrexMex is offline   Reply With Quote
Old 12-07-2010, 10:09 AM   #4
Lift
Lift's Avatar
Vehicle Year: 1983
Default
i knew it! well im going to replace the IAC and i already bought mafs cleaner and cleaned it a while back. You know it really helps when your going to school for this stuff =D.
Old 12-07-2010, 10:22 AM   #5
xentris02
Vehicle Year: 1993
Vehicle Make: ford
Vehicle Model: ranger xlt
I use this vehicle for: daily driver, snow crawler,mudder, teenage stuff
xentris02 is on a distinguished road
Default
i had the same problem and my truck was even throwing iac codes and turned out to be tps. it would only happen when it was cold out so it took me last winter and this fall to figure it out
xentris02 is offline   Reply With Quote
Old 12-07-2010, 01:13 PM   #6
Lift
Lift's Avatar
Vehicle Year: 1983
Default
I replaced my tps didnt do a thing. I even unpluged it while it was started then plugged it back in it brought it up to 1100 rpms but still bogged and when i restarted the truck it went right back up to 1600. I unpluged the iacm with the engine running and it dropped the rpms to 600 and stopped bogging. Eather i got a bad computer or the module is bad.
Old 12-07-2010, 02:43 PM   #7
TrexMex
TrexMex's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Default
Quote:
I really wouldn't blame it on the computer... take out the IAC valve, give it a good soak in carb cleaner, rinse and install... it might be stuck. If that helps go ahead and replace it.. it won't be long before it gets stuck again.
__________________
My build thread
Old 12-07-2010, 02:52 PM   #8
TrexMex
TrexMex's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Default
OH and BTW I believe idle RPMs are ~900, but that might only be for manual transmissions; will need someone else to back that up..
Wouldn't hurt to check it, though...
__________________
My build thread
Old 12-07-2010, 03:05 PM   #9
Lift
Lift's Avatar
Vehicle Year: 1983
Default
I got a 4.0L 5sp maunul. It should not be at 1600. It was probably running on such low rpms when i unpluged it because it has nothing to tell the engine what to run at. So if i replace it or clean it it should be around 800 i beliave.
Old 12-07-2010, 06:00 PM   #10
Lift
Lift's Avatar
Vehicle Year: 1983
Default
it died when i unplugged it. the 3rd time i started it i was reving it up to keep it alive
http://www.youtube.com/watch?v=vnWU9yq1ZTE
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
