Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 02-14-2010, 01:24 PM   #13
IlovemybroncII
IlovemybroncII's Avatar
Year: 1990 1998 198
Make: Ford Chev For
Model: BroncoII C3500 BroncoII
Engine: 350/2.9/2.9
Class: 2wd/4x4/sas
Used For: to hide the dollars i dont have
IlovemybroncII is on a distinguished road
Send a message via MSN to IlovemybroncII
Default
ok this is just another hint may or may not be problem but on my 05 f250 i would get high rpms and no power run like crap throw all kinds of codes and what it end up being was the screen on the fuel pump was so cloged up with crap would get fuel then it would not I removed screen and that was a big mistake truck would not run at all put new way too damn costly fuel pump in run like new hope this helps
IlovemybroncII is offline   Reply With Quote
Old 02-14-2010, 02:27 PM   #14
shawn.m
shawn.m's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4 Extreme
Used For: search and rescue, play
shawn.m is on a distinguished road
Default
remember this is a 93 4.0 with MAS air and dual O2 sensors. I have a Air/Fuel O2 meter sitting on my shelf that I think I might throw on just for fun.
TPS voltage is .95 at close with a smooth trip to 4.5 -TPS and MAS sensor were both replaced.
I am thinking of dropping the tank and cleaning it just to make sure that the fuel pump screen is not plugged or blocked. Has new fuel filter also.
bought a fuel pressure gauge today so I can do the KOEO fuel pressure test and the running one.
__________________
1989 B2 - 1993 4.0, M50D, BW1354M, D35 4.10 LS, warn manual hubs, 8.8 4.10 LS disc brakes, 2" shackles, Xterrians 33x12.5, 6" superlift, SS lines , Optima , hatch cut off, Smitty XCR8 winch,
shawn.m is offline   Reply With Quote
Old 02-14-2010, 08:44 PM   #15
shawn.m
shawn.m's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4 Extreme
Default
ran new vacuum line from EGR purge solenoid to EVAP cannister.
Opened my new Fuel Pressure Gauge. Fuel pressure KOEO fuel pressure was 38psi, steady state 32PSI and goes up to 39PSI as soon as you hit the gas. So that is not the issue. Vacuum steady state is 18 in.
Big thing I noticed after doing all the Grounds correctly and redoing the positive cable was that the charge voltage shot up to 16volts. Drove it around the farm again for a while charging the battery. Now the hesitation dieing is gone!
Idle is now 1000 rpm and it runs great! Lots of power down to 1500rpm and up to 5500. Had all 4 wheels spinning in a mud puddle
SO STOKED! :
So final analysis may be that battery voltage was not where it needed to be and then the computer needed to relearn everything after proper grounding was done.
next up is smog test and title transfer
__________________
Old 02-15-2010, 05:27 PM   #16
IlovemybroncII
Year: 1990 1998 198
Make: Ford Chev For
Engine: 350/2.9/2.9
Class: 2wd/4x4/sas
Default
yay very happy you found problem way to go
Old 02-15-2010, 05:41 PM   #17
shawn.m
shawn.m's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4 Extreme
Default
well today after running good for 30 minutes it started doing its bucking and dieing thing again! grr.
__________________
Old 02-15-2010, 05:44 PM   #18
IlovemybroncII
Year: 1990 1998 198
Make: Ford Chev For
Engine: 350/2.9/2.9
Class: 2wd/4x4/sas
Default
shit
Old 02-15-2010, 08:32 PM   #19
master hec0
Canada Eh?
master hec0's Avatar
Year: 2011
Make: Ford
Model: Ranger
Engine: 4.0L V6
Class: 4x4 Sport Epic Canadian Edition
Used For: DD,offroading
master hec0 will become famous soon enough
Default
do the o2 sensor seriously everything sounds identical to what mine was experiencing i would fix one thing and it would seem to work good but then i would notice it about 15-30 mins after driving it.
__________________
Quote:
Originally Posted by MikeWild View Post
Change my OIL?????? I suppose next you'll tell me I have to put gas in the thing too!
master hec0 is offline   Reply With Quote
Old 02-15-2010, 08:49 PM   #20
shawn.m
shawn.m's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4 Extreme
Default
about what I said =(
ran another ground from battery to frame. going to add a air/fuel ratio gauge tomorrow if I have time.
have to watch and see if the voltage meter goes to 0 also next time. doesn't seem to affect the starting circuit. so it is in the electrical or fuel circuit. Need to start reading the electrical diagrams
__________________
Old 02-15-2010, 08:53 PM   #21
kimcrwbr1
kimcrwbr1's Avatar
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Used For: DD tow boat
kimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nicekimcrwbr1 is just really nice
Default
I dont know if it has been asked about the computer you say the harness was changed with the engine is the computer different also. I know it is a stupid question but sometimes things get overlooked
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 02-15-2010, 10:48 PM   #22
shawn.m
shawn.m's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4 Extreme
Default
believe the computer was changed with the dash swap. the swap was done in 2000 according to BAR sticker on door. So this is a new issue.
__________________
Old 02-15-2010, 11:00 PM   #23
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
I know this is a bit off topic, but you know that those air/fuel exhaust meters are just glorified O2 sensors, right?
R+R your O2, see if it fixes anything, it really does sound exactly like an O2 sensor issue.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 02-15-2010, 11:24 PM   #24
shawn.m
shawn.m's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4 Extreme
Default
well the o2 meter that Im putting on is really a glorified volt meter. it plugs into the hot signal wire and shows a graphic output of what the voltage going back to the computer is.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
