hub o ring
canyoncritter
6
San Diego
Willys,Ford,Jee
any one have a part number or "Size" as I have a hydrolic shop near me that has o-rings up the yin yang.....
thanks
Ranger5.0
Lindsay Ontario
I have some John Deere part #'s if you want. The orings i used were a big thicker then the stock ones tho. and they were expensive. Thank god i work there tho why not use RTV?
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
Ford pt#
FOTZ-1K106-A
canyoncritter
6
San Diego
Willys,Ford,Jee
thanks junkie.................
yeah whats the JD parts number.....think my buddy has a cross ref book on JD parts.Maybe I can pull some specs,then hit up the hydrolic shop.
cause 12 bucks each argghhh.....just may pull the RTV trick...only thing is I know the hubs will be pulled down abunch checking on wheel bearings
projectnitemare
Solid Axle Swap
RBV's on Boost
8
Osceola Mills, Pa
396W
I was just wondering the same thing. I need to replace about 8 of them on all the RBVs I own and work on.
Matt
NVR2FST
I actually just measured them and bought 5 of them for $5 from a bearing store.
canyoncritter
6
San Diego
Willys,Ford,Jee
Man, thats like saying your g.f just got a set of bolt on's and not posting any pics.......
care to share the info, as my O-rings are playing a game of hide and seek.They are hiding till I buy some replacements,then murphy law will return them as normal....
NVR2FST
Sure...what do you need to know? We just had a local place that sells bearings and we just told them what we were looking for and they matched it up.
Staff online
Shran
April Truck of The Month
