94 XLT Ranger 4.0 AT 3.08. Towing Capacity?
ctgriffi
15+ Year Member
Tennessee
Hey guys, I've got a 2WD 94 that I've been taking real good care of since I bought it 8 years ago. I'm thinking about bolting a good hitch onto it and maybe towing a small camper around my state (TN). The owner's manual lists a pretty low towing capacity for the AT 4.0 with the 3.08 rear axle - something like 2300lbs. Does that sound right? If I drive without OD, could I reasonably expect to do better than that number?
Thanks for the advice.
You can do better, but not guarunteed good reliability or gas mileage. I would swap in a set of 3.73's at he minimum and get a tranny cooler and you can do better than 2300. Those are mild overkill but better safe than sorry. Make sure to keep your brakes maintained as well.
Yeah, from what I've heard recently, your advice sounds like...good advice. But why did Ford sell so many of these trucks with the 3.08 rear? I guess it's gas mileage, right? But, who buys a 4.0L pickup for the mileage?
I'll look into the 3.73 axle and the tranny-cooler installation. Thanks for the help.
you could always go to one of the ultralight tent campers that come in around 1,000# or less. i have one and it's great. just a thought.
i have one of the pop up tent trailers and my dads old nissan 2.4 4 banger handled it ok then he got the ranger same setup 4.0 w/ 3.08 rear and you couldnt even feel it on the back. its a manual trans but shouldn't make that much of a difference
Keep in mind, however, that legally you're only going to be allowed to tow a certain amount. The truck may be capable of towing more than that, but if you ever get put on a scale, you not only get hit with a fine, but also you get hit with an added fee for every pound over the limit. You can petition to have the GCWR (Gross Combined Weight Rating) raised on your vehicle, but you have to show improvements in both power (engine/gears/trans/etc) and stopping (brakes/trailer brakes).
I have no idea what the GCWR would be for your truck, however.
Small Camper - Ranger Towing
Yeah, I've thought about looking into one of those pop-ups before; I might do that. What I'd really like is one of those fully-enclosed travel trailers that are around 15'. Some of those actually come in under the 2300lb tow-limit stated in my manual. One decent bed with a kitchenette and small bath would be perfect for me and my wife...
I have an equation for you:
4.0 Power + steep 3.08 gear + trailer = dead A4LD
I wouldn't drive an A4LD, let alone try to tow with one, without a huge trans cooler. A4LD's have no trouble cooking themselves in a 2wd 2.9 w/ 3.45 gear.
The Ranger as a tow vehicle is perfectly capable of handling a pop-up camper. But if I was going to use your truck I would get the biggest trans cooler you can fit behind the grille (www.summitracing.com is a good place to look), 3.73 gears, and a trans temp gauge (you can use a $15 engine temp gauge hooked up to the trans cooler line) that you watch very carefully. Then I would be comfortable towing with it.
Of course the ultimate towing upgrade would be the manual trans with 3.73 gear.
Sevensecondsuv: Thanks for the advice. I hear what you're saying about the tranny cooler, for sure, and I plan on looking into that...
So, you really prefer the MT towing setup you described, huh? I understand the 3.73 recommendation, but most people I've talked to (and my owner's manual) recommend the AT for pulling heavy loads...like it's better equipped to manage the stress of towing than a MT. But, maybe I'm misinformed...?
Axle ratios, trannies, towing capacity
So, I don't know much about all of this stuff, but I really enjoy learning what I can. Maybe somebody can/will speak to the below scenario:
I used this calculator and this tranny info to see the implications of using a 3.73 vs. my current 3.08. I found that, driving at 66 mph - in DRIVE - my engine is revving at about 2600 with my 3.08 axle (in OD, about 1950 rpm). With the 3.73 rear-end, at the same 66 mph, my engine is turning at 2350 in O.D. and 3150 in Drive.
Based on this, it looks like it's a good idea to not use OD while towing with my current 3.08 rig. But, would there be any great advantage in towing with the 3.73 in OD versus the 3.08 in Drive? Hope I'm making a little bit of sense here...trying to understand the relationships between rpms, gear ratios, tranny reliability, etc.
Yeah I see your point about OD. It's true that towing in OD should be avoided, in which case 3.08s would be better for going down the highway than 3.73s. But the other thing to consider is starting out when you're in 1st and accelerating through 2nd. With 3.08s, the torque (and therefore stress) on the transmission while you're accelerating (keep in mind climbing a hill at constant speed is the same as accelerating) is about 21% (3.73-3.08 / 3.08) greater than with 3.73. This is what will cause the transmission to overheat.
As far as towing with a manual, Ford underrates the manual transmission tow capacity to avoid excessive clutch replacements under warranty due to people who aren't very good with a clutch trying to tow with one. In and of itself, the manual transmission is just a set of cast iron gears that mesh and transmit power through the transmission. In this sense it is much stronger than the multiple clutches and bands in an automatic that basically use friction (which means a lot more heat) to transmit power through the trans.
Towing with a manual you'd definately want 3.73 or 4.10 rear gears because that it what will make the difference between burning your clutch trying to get started with the trailer and being able to engage the clutch without revving the engine and burning the clutch.
A ranger with a manual transmission, 3.73 or 4.10 rear gear, a good quality clutch, and good driver (knows how to work a clutch) will be more reliable pulling large trailers than an auto.
But I agree. From the driver's standpoint, it's definately much easier to tow with an automatic.
OK, that all makes a lot of sense to me. I wasn't thinking about the issue of low-speed towing, taking-off from a stop with a trailer, etc, but I can see where it would really help to have the 3.73 in those scenarios.
Great info - thanks!
BTW, although I've never done much towing with this truck (obviously), I just hit 163K with the original A4LD. Only thing I've ever done to that transmission was change the fluid - once!
Yeah, the A4LD tends to get a bad rap, which is generally well deserved, but there are the occasional stand outs. My buddy had a 94 Explorer 4x4 that 23x,xxx when the 4.0 finally dropped a valve. The original A4LD was only starting to slip. Also my uncle has a 93 3.0 Ranger with an A4LD that has something like 220,000 on it and still works fine so long as you fill up the transmission every other time you stop for gas.
my original a4ld has 233000 miles on it and i have to add a little fluid every once in a while and the shift from 2nd to 1st has a little jerk to it, but other than that it runs like a champ. oh and i off road with it and pull my boat with it to so they are good trannies in my book.
