Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-28-2008, 10:05 PM   #1
ncsdaonex
ncsdaonex's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Ranger
ncsdaonex is on a distinguished road
Default how do you remove the pilot bearing?
i have a 1990 2.3 4 cylinder 2wd 5 speed, now i tried getting the pilot bearing out. i took off the flywheel. i took a screwdriver and a hammer and tried to beat it out, i probably shouldnt have done that. i broke out the little bearings, but the ring part of the pilot bearing wont come out so hoe do i get it out, i have a new one to put in
ncsdaonex is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-29-2008, 01:20 AM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
try and find a bolt that fits inside the pilot bearing very snug, fill the hole will grease and then drive the bolt in with a hammer, should pop it out for you. Doesn't hurt to put a rag over it as you are doing it so you don't get a grease in the face.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 12-29-2008, 10:31 AM   #3
ForOffRoadDriving
ForOffRoadDriving's Avatar
Vehicle Year: 1994
Vehicle Make: FORD
Vehicle Model: RANGER
I use this vehicle for: EVERYTHING A RANGER CAN DO, AND LOTS OF THINGS IT SHOULDN'T
ForOffRoadDriving has a spectacular aura aboutForOffRoadDriving has a spectacular aura about
Default
yep, thats the method ive always used. i actually have a spare input shaft that i use, but its the same concept. it sounds like from your post you already have the inner race and the bearings out and now youre stuck with a stubborn outer race thats not wanting to come out of the flywheel. you can use a cold chisel and try to cut the race by beating it with a big hammer, or you can use a die grinder with a small bit and cut the side of it so that you can pry it out. hope that helps you out.
__________________
1994 Ranger 4X2 Off Road, Built Not Bought!
http://www.therangerstation.com/foru...ad.php?t=37621
ForOffRoadDriving is offline   Reply With Quote
Old 12-30-2008, 11:05 PM   #4
greasemonkey01
Junior Member
greasemonkey01's Avatar
Vehicle Year: 1990,1978,2004
Vehicle Make: All Ford
Vehicle Model: Bronco II, F-150,F-250 Super Duty
greasemonkey01 is on a distinguished road
Default
Ok, here's how you can get it out... grab your MIG welder or ARC welder, crank that thing up and weld a bead around the entire face of the race. flip it over and smack it with a hammer. It might sound a little crazy but it works every time... The heat of the bead pulls the entire race inward and will actually shrink the race and will come right out.
greasemonkey01 is offline   Reply With Quote
Old 12-31-2008, 01:24 AM   #5
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
How about find a socket or something that's just barely smaller in diameter than the bearing and just tap it out from the backside of the flywheel? Should be real easy since it's already off the engine.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 12-31-2008, 09:49 AM   #6
MAKG
RBV Technical Advisor
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Explorer
MAKG will become famous soon enough
Default
Junkie's method is FAR easier than all the Rube Goldberg suggestions....
Put the flywheel on two wood blocks and tap the bearing out with a socket and a light hammer (no bigger than a standard claw hammer). Very easy, very quick, and doesn't require ruining your flywheel with a stick welder (it ain't gonna be flat after that....). Use the largest size that is smaller than the bearing 's outer diameter.
The grease method works if the bearing is in the crank and works a whole lot better for pilot bushings because they are airtight. If you try this on a flywheel, you'll just squirt grease all over the ground.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 01-02-2009, 11:36 AM   #7
ForOffRoadDriving
Vehicle Year: 1994
Vehicle Make: FORD
Default
I guess what we need to know is whether or not the pilot bearing is in the end of the crank or if it is in the flywheel? IIRC my 90' 2.3l had the bearing in the end of the crank and so does my 94' 3.0l. if that is the case then you cant hit it out form the back side cause you cant get anything in there.
__________________
Old 01-02-2009, 12:15 PM   #8
Mutant Pony
Mutant Pony's Avatar
Vehicle Year: 1977
Vehicle Make: Ford
Vehicle Model: Pinto
I use this vehicle for: Mud racing/trails
Mutant Pony will become famous soon enough
Default
This is NOT a cologne engine guys. The 2.3 pilot bearing is in the crank. Most of you that replied should know that. ONLY cologne engines have the pilot in the flywheel.
The first time I encountered a failed roller pilot I tried everything I could think of to get it out. I ended up using a diegrinder. That is how I've done it ever since.
There is a pilot bearing removal tool that fits on the end of a slide hammer. If you can borrow or rent one, it may work for you.
__________________
'84 Ranger, 351c,C6,208,EBsas."DeRanged Mudder"
'86 Ranger, 3.0swap,coil rear suspension"Black Frog"
Mutant Pony is offline   Reply With Quote
Old 01-02-2009, 12:31 PM   #9
MAKG
Vehicle Year: 1991
Vehicle Make: Ford
Default
It sure sounds like he's trying to beat the pilot bearing out of something a screwdriver might be useful for....
FWIW, you can get a pilot bearing puller from Harbor Freight for $10 (or rent/borrow one). The business end is the same as those slide hammer ones, except it's a whole lot easier to control a screw puller than a slide hammer.
http://www.harborfreight.com/cpi/cta...temnumber=4876
__________________
Old 01-04-2009, 11:24 AM   #10
rneal55555
Vehicle Year: 2000 1999
Vehicle Make: FORD FORD
Vehicle Model: Ranger Super Cab Ranger Super Cab (sold)
I use this vehicle for: Daily Driver
rneal55555 is on a distinguished road
Default
Last time I had to remove a pilot Bushing (not a Bearing) with out having a puller handy. I used a tap (which was handy) just screwed it in until it bottomed out in the hole and kept turning until the bushing popped out. The bearing race is a lot harder and I'm not sure the tap will actually cut threads in it, but if you get one that just barely cuts threads in it it might work.
rneal55555 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
