Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Ranger Axles
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Reply
Thread Tools Display Modes
Old 10-01-2008, 04:55 PM   #1
Pavoner
Pavoner's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: MORE THAN I SHOULD!
Pavoner is on a distinguished road
Thumbs up Front Axle Stub Shaft removal.
It looks like I will be replacing U-Joints on the front axle on my, 1997 Ford Ranger (think it's a Dana 35...) 4.0L, Auto (5R55E), extended cab. The right front (outboard) seems to of developed a lot of play in the last 4 months (last time I checked them...). I haven't had a chance to get under there and check the one on the stub shaft, but I am unable to find info on removing the stub shaft either in my Chilton manual or on here... Does it just pull out or is there a "C" clip in there that needs to be removed like the rear axle? I have never had to do U-Joints on a Ranger before any other thing you guys think is pertinent please don't hesitate to let me know.
Thanks again,
Chris
Pavoner is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-01-2008, 05:46 PM   #2
97BlackBetty
97BlackBetty's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: D.D.
97BlackBetty is on a distinguished road
Default
I did a write up in this thread towards the bottom.
Click Here
__________________
Justin: 97' Super Cab= Sold
97BlackBetty is offline   Reply With Quote
Old 10-01-2008, 05:49 PM   #3
engdept
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: Daily Driver
engdept is on a distinguished road
Default
If you have to do the outer u-joint (the one closest to the tire), just remove the boot that is in the middle of the passenger side shaft and the outer u-joint will pull out. If it is the inner, you have to remove the pig to get the c-clip out of the carrier so you can remove the axle.
If you remove the axle, you should do the c-clip eliminator mod so you NEVER have to pull the pig again to change a u-joing. Here is a how-to for it:
http://www.therangerstation.com/foru...ad.php?t=26488
engdept is offline   Reply With Quote
Old 10-01-2008, 06:10 PM   #4
Pavoner
Pavoner's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Default
Wow, that sucks! Thanks for the info sorry for starting a new thread when there was already a write up. Man do I hope I don't have to change that U-Joint!
Old 10-01-2008, 06:12 PM   #5
97BlackBetty
Vehicle Year: 1994
Vehicle Make: Ford
Default
The first time I did u-joints on my truck it took me and 2 buddys three days to get it all buttoned back up. Now I can tear the whole front end out, change joints, and put it back, in about 2 hours. But yea, the first time is a little intimidating.
__________________
Old 10-01-2008, 06:56 PM   #6
Pavoner
Pavoner's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Angry
anyone ever tried to change the inner U-Joint without removing that whole pig? is there any reason Ford would not of put just a regular diff cover on the front of the beam? strength? just currious/angry/scared... don't wan't to tear that thing outa there!
Thanks again all!
Old 10-01-2008, 06:57 PM   #7
engdept
Vehicle Year: 1989
Vehicle Make: Ford
Default
It is SUPER easy to take the pig out and put it back. If you read the how-to on the c-clip eliminator and do it, you wont have to take the pig out anymore.
The ONLY way you learn is to do.
Old 10-01-2008, 08:09 PM   #8
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
You can do it in place, but you need to torch the old joint out and use a u joint press to get the new one in.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
