Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 07-29-2011, 12:44 PM   #1
dorough
Junior Member
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: 2.3L Ranger XLT Regular Cab
dorough is on a distinguished road
Default 94 Ranger - Do I have an AC leak or what??
My AC was fine until a week or so ago. Not much air was coming out, and the air I was getting was not nearly as cold as it used to be. I figured I was low on coolant since I could hear the compressor clutch clicking in every 5 seconds or so. So I gave it a R-134a coolant charge and immediately felt the ice cold air coming out again and the compressor clutch cycled much slower.
As luck would have it, the next morning the blower motor completely gave up the ghost before I could even get on the road. So a couple days later, I replaced the blower motor along with the motor resistor and cleaned a handful of leaves out of the evaporator case.
So now I'm thinking new motor, new resistor, charged system... time for some cold air! Nope. I have plenty of air blasting in but it's not cooling at all. And the compressor is back to the fast cycling again. So where do I begin to look? How do I know if I have a leak or if it's something else? And if it is a leak, what's the best way to find it? I'm not an AC moron, but I ain't no AC rocket scientist either, so whatever you can throw my way to chew on I'll appreciate!
dorough is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 07-29-2011, 04:41 PM   #2
Stoodybayker
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger 4x4
Stoodybayker is on a distinguished road
Default
Cycling compressor is s sign of a low charge....sounds like you have a leak, and it's getting worse. There are leak detectors that you can put in, and use a UV light to see where it is...but the most likely place is the compressor seal.
Stoodybayker is offline   Reply With Quote
Old 07-29-2011, 06:04 PM   #3
dorough
Junior Member
Vehicle Year: 1994
Vehicle Make: Ford
Default
I guessing the compressor seal would be the seal around the shaft? I should be looking first of all for leakage on the front of the compressor?
Old 07-29-2011, 06:29 PM   #4
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
That would be there I'd start looking for sure. Other places to check though are the hoses, and the spring-lock fittings where the hoses are connected to the condenser, as well as the one on top of the accumulator/drier (fairly frequent spots for it to leak).
Usually you will find an oily residue around a leak, so be looking for that if you don't have a detector.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 08-07-2011, 04:45 PM   #5
dorough
Junior Member
Vehicle Year: 1994
Vehicle Make: Ford
Default
Ok, I finally found time to check this problem out a little more. I haven't found any visible signs of AC refrigerant leaking anywhere. The compressor was still cycling pretty fast - every couple of seconds - and the pressure was cycling up and down on the gauge. So going under the assumption that the refrigerant level was low, I hooked up a can of refrigerant. As it went in, the compressor cycling slowed down and eventually stayed engaged full time with a constant pressure reading of 28-30psi. So I got in the truck to check the air temp and it was slightly cool... not cold by any means. Granted, it's almost 100 degrees today, but I would still expect it to be colder. Additionally, I never noticed any condensation on the AC lines... not sure if it wasn't going to form or if it would've just needed more time. I only let it run 5-10 minutes. Any ideas what I'm dealing with here?
Old 08-08-2011, 07:36 AM   #6
dorough
Junior Member
Vehicle Year: 1994
Vehicle Make: Ford
Default
--UPDATE-- Well, this morning after driving about an hour, the air seems to be maintaining its coolish temperature - not getting any colder, but not getting any warmer either. So now, I'm wondering... is it possible that it's just really low on refrigerant? The truck is 17 years old. Could it be that maybe there was a tiny leak somewhere and the little bit of refrigerant I just added - which, by the way, had leak sealant in it - plugged the hole?
Along the same lines, if the system is low on coolant, combined with the fact that I don't want to overcharge the system - could it be that I'm just not filling it up enough? I see all the warnings about DO NOT OVERCHARGE YOUR SYSTEM. Again, I'm not an AC whiz. How do I know if it has enough in there or not? And how do I know if it's being overcharged? The fact that it's holding its slightly cool temp makes me wonder if I just need to add more. I only put in about 3/4 of a 7oz. can between the last two charges. And the label on the evap coil box says Max. 7 lbs. Should I put more in without fear of overcharging?
Old 08-08-2011, 09:14 AM   #7
press 1 for english
press 1 for english's Avatar
Vehicle Year: 2007
Vehicle Make: Ford
Vehicle Model: Ranger XLT Supercab Blue
I use this vehicle for: Pleasure...drive to work
press 1 for english will become famous soon enough
Default
Why don't you do the proper thing and check the pressures when charging so you don't overcharge?????????????
The proper amount of refrigerant charge is listed on the radiator support bracket and should be 2 lbs or so.
press 1 for english is offline   Reply With Quote
Old 08-08-2011, 11:36 AM   #8
dorough
Junior Member
Vehicle Year: 1994
Vehicle Make: Ford
Default
Interesting stuff going on here. I just took it for a ride (in the 100 degree heat!) and noticed that the compressor cycling was back to every 2 seconds. BUT when I stopped the truck and let it idle, the compressor stayed engaged and there was a slight cooling to the air coming in. Took it back on the road... warm air & fast cycling again. So is this definitely sounding like a refrigerant leak now to anybody, or no?
Old 08-08-2011, 02:42 PM   #9
press 1 for english
Vehicle Year: 2007
Vehicle Make: Ford
Default
Put a freaking set of gauges on it or live with the heat until fall.
Old 08-08-2011, 03:12 PM   #10
dorough
Junior Member
Vehicle Year: 1994
Vehicle Make: Ford
Default
Hey Press 1, did you see the part where I said I'm not an AC whiz? I'm guessing not. Thanks, though, for your sarcastic remarks. Hopefully somebody here will have some answers without attitude.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
