Another 4.0 ohv to 4.0 SOHC swap question
dsm21
Hey guys I am considering swapping out my 4.0 ohv (Blown head gasket) for a 4.0 SOHC.
I have a 99 XLT 4X4.
I have been researching this and I know it has been done usually on older trucks late 80s early 90s with different model year engines....
But my question is If I got a hold of a 99 Explorer 4.0 sohc engine could I just drop it in without doing any real modifications???
I heard of guys use a sohc on a ohv computer :shok:
I also stumbled across this thread. (FIrst post)
http://www.explorerforum.com/forums/showthread.php?t=331549
Any and all help is welcomed. Thanks
snoranger
Professional money waster
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
I didn't ask for your life story, just answer the question!
Been there... Done that. I wouldnt go that route... Use the correct computer and harness, it will make your life a lot easier.
As far as bolting it in, everything should bolt up fine since the front half of the trucks are virtually identical.
dsm21
The expert himself!!! :yahoo:
Thanks bud for anserwing my question, probably gets annoying after hearing it so much.
I do have another question though with the new ecu / computer will the other harnesses plug in the new computer and work correctly? :icon_confused:
Also what years would best work for a direct plug and play? 99 would be the ideal correct?
snoranger
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
I don't think you'll find a plug and play computer harness, I could be wrong though. The wiring may need to be modified some, but should be close. I'd look for a 98-00 SOHC and take everything from the fan to the y-pipe, Air cleaner to motor mounts. Just pick up the Ford EVTMs (search eBay) for both the donor and recipient vehicles, you'll have everything you need to rewire it to work.
The engine harness may even have different plugs on it then the body harness... If you have to cut and splice wires, solder and heat shrink is the only way to make a permanent connection that will last in the engine compartment.
dsm21
Wait if I got the SOHC engine, harness and computer what would need to be spliced??
snoranger
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
I'm assuming that some of the connections between the body harness and the engine harness may not be the same. I may be wrong and it might just be plug and play... But never assume Ford made it that easy for you. (If there are any differences, it shouldn't be much.)
dsm21
Thanks bud, I actually just learned how to sauder yesterday :headbang:
So I thik I can definatelly do this swap.
snoranger
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
Good... the next step is to learn how to spell solder. :thefinger:
The swap shouldnt be too hard.
Make sure you get the powersteering hose.. Thats different between the motors. (I also found that the steering cooler was different, but that might be a model year difference, not engine.)
The Y-pipe was different. They looked the same but were off by about 2".
The tranny should be the same.
Any vacuum line that goes to the body should be the same.
The A/C hoses are different.
The fan, rad hoses, shroud are all the same.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
649
Central Indiana
3.0
Why the SOHC?
snoranger
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
dsm21
Will do :icon_cheers:
Why the SOHC?
I honestly just want more horsepower Correct me if I am wrong because I have only be researching the engine for about a week or two. But the OHV engine has 160 hp and the SOHC has a little over 200.
I plan on hauling cars and from what I read the sohc engine has higher hp and high torque overal except under 1500 rpms or so the the ohv has a little more torque.
I am think about just putting a new head gasket on there and call it a day, because I am really concerned about the timing chains :icon_surprised:
Snow Ranger you have a ton of experience with these motors what is your opinion?
snoranger
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
They feel about the same under 3000-3500 rpm. Unless you drive like me (aggressive, to say the least), you'll never notice the difference.
dsm21
I guess you didn't read my intro thread or no what a dsm is. I have a 95 Mitsubishi GSX Turbo All wheel drive. Pulling down about 240/250
So yeah I do drive a little agressive :icon_cheers:
snoranger
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
I know what a DSM is. I own a Cobra... I've seen quite a few DSMs get smaller and smaller and smaller and smaller in my rear view mirror.:icon_rofl:
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Oh, smackdown fail.
No, Know. Gotta use the right one man.
Members online
No members online now.
Today's birthdays
Mudtruggy
May Truck of The Month
