anyone used this when rewiring cluster?
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
3,614
I found a solution that is even simpler.
Go back to your original harness, and find the thick black wire that goes from the ignition switch to the gauge portion of the cluster and put it in your new setup. It's a 9-oh resistor and steps the voltage down to the correct level.
Angie
368
92 & 83 project
4.0L 302
thanks ads, i will look into that wire, isn't one of them a fuseable link also?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
theres a resistor wire on some systems and reg voltage regulator on others... and ...well technically a fusible link is a resistor wire....but...
Angie
368
92 & 83 project
4.0L 302
Thanks bob, Back to original question, Will these step down converters work ok for a converter?
3,614
I don't know why it wouldn't. As long as you have a clean consistent 5V it shouldn't really matter how you do it.
