4.0 ohv to sohc swap with m5od-r1
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
So I have a big oil leak out of the Rms only about 7k on it. Figured I got to pull the motor anyways why not get more power. What would be involved with a 4.0 sohc swap using my ohv tranny?
stegomon
20
auburn/minot maine
fords and only
big chunk of wiring harness, ecu. engine, maybe every thing under the hood and some under dash things
swynx
9
lewiston idaho
Mazda
4.0
i know that they have the same bolt pattern. well, the sohc has 2 more, but they bolt together fine, and i know that you can run the sohc on the ohv computer, the only problems is the power steering, you gotta have a new end put on. read racin n drummins, b2 build thread. he goes over it.
cp2295
7
Washougal, wa
Wow so you guys are telling me the sohc will run on an ohv computer with no check engine light and no problem? That cmp sensor no being plugged in won't throw codes? And it won't run like a dog? How in the hell does a obd 1 computer run an advanced obd2 system!? That's pretty awesome I'm really considering the swap now.
My ohv rattles like crazy with that marbling noise has low oil pressure and has a weird valve train noise over 2500k (if I let off the throttle or lightly apply it).
I'd really like that 50 hp and better mpg too, IF it'll run on the ohv computer. I want Ron to verify that[emoji23]. He's the computer/wiring master.
So do I use a sohc clutch/flywheel with the m5od r1 I got (the non HD) or do I use the ohv flywheel/clutch?
cp2295
7
Washougal, wa
Considering also I have obd 2 I could program the computer right? I just don't want to swap a sohc PCM in because of the dash wiring and pats to deal with
swynx
9
lewiston idaho
Mazda
4.0
i havent done this swap myself but i have read several build threads, where they have used the sohc with a ohv computer, specifically "racin n' drummin" he has the first build thread that i read where someone swapped a sohc in. like i said he goes over the whole process in his build thread.
from what i remember reading the only thing it limits is your redline, because the ohv has a lower redline.
also, i dont remember if pats is a problem with later year engines. but i seem to remember reading that using a ohv computer eliminates that problem.
i have though long and hard about a sohc swap, but seeing as tho 5.0 explorers are a grand and a sohc in my area is a grand its a toss up. but the sohc has got basically the same hp of the 5.0 just a little less torque.
as far as obd1 running an obd2 system... the engines are the same asside from one being sohc and one ohv, thats why its still a plug and play swap, there was one thing i remember reading about that was a concern, because the ohv does not have it and the sohc does have it, but no body ever ran into any problems. so as long as your sohc sensors are good then there will be no check engine light.
theres some really good info on this on the explorer forums.
i assume since you can use the transmission on iether engine to go with the transmission parts for your engine, so sohc parts.
PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
176
Millersport, OH
Engine Type
V8
2WD / 4WD
Solid Axle Swap 4x4
The SOHC has the same bell pattern....except the upper right hand hole is moved down 2" (timing chain interference)....the M5OD found in the SOHC will have both the OHV and SOHC pattern.
PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
176
Millersport, OH
Engine Type
V8
2WD / 4WD
Solid Axle Swap 4x4
If you need a SOHC compatible M5OD housing let me know
trader007
2
why on earth would you get rid of the indestructible OHV motor?!??!?
cp2295
7
Washougal, wa
Because I like the better hp/torque and don't really mind swapping motors, but to clarify use the sohc clutch and flywheel?
Cool thing too I just passed emissions so I got two years to figure out any check engine lights if need be
cp2295
7
Washougal, wa
Well rockauto shows them as having the same clutch and flywheel on a 98 explorer. I got a 98 ohv, so I'll just use my old clutch/flywheel, only got 5k on it and it's luk. That's pretty awesome [emoji3]
When getting a sohc at the jy what specifically should I look for? When I have the motor on the stand I'm gonna pull the timing cover and inspect everything what exactly should I be looking for with the chain?
I know to smell the oil and pull both cam covers and look for shavings/sludge. Also gonna cut the oil filter and see what's up.
cp2295
7
Washougal, wa
Do you have the link to his thread? I searched on google and couldn't find anything
cp2295
7
Washougal, wa
swynx
9
lewiston idaho
Mazda
4.0
Found his thread: http://www.therangerstation.com/forums/showthread.php?t=35258
I have full faith my obd 2 1998 ohv ecu will run the sohc no problem. And since I got obd2 I can just get a tuner to change the redline.
I'm excited! This is gonna be an awesome swap.[emoji3][emoji106]
that would be the thread.
a lot of people like to bitch about the sohc timing chain tensioner (part that lets go), but ive seen a lot of them go to 250k miles on the allegedly bad part, while you have the sohc out, i would suggest replacing all the timing chain parts. all of the timing tensioners that are in auto parts store now are an improved part. so it shouldnt fail any time soon. take a read here.
http://www.fordrangerforum.com/4-0-sohc-4-0-ohv-tech/107857-what-failed-chain-tensioner-does.html
as far as checking the engine at the junkyard i would try and see if i could turn it over. if theres no contaminates in the filter you should be alright.
Staff online
Members online
Shran
April Truck of The Month
