- Aug 31, 2010
- Reaction score
- 2
- Location
- Oregon
- Make / Model
- Ford bronco 2
- Engine Type
- 2.9 V6
- Engine Size
- 2.9
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 5.5 in susp 2 in body
- Tire Size
- 35 1250
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Lots of axles have two tags. One IDs the axle, gives the gear ratio, and has what I believe to be a serial number. The other generally specifies the type of lubricant to be used.I seem to recall having seen two tags on some axles... Is there another tag on it maybe?
