wondering what this gear ratio is
Harley
Oregon
Ford bronco 2
2.9
5.5 in susp 2 in body
the ratio ends in a 4.....any ideas?
Mac
183
C. Wisconsin
2000
199
What car/truck? Looks like a 4.15 to me but totally unfamiliar with that design, sure no a common one to me.
Dave
Harley
Oregon
Ford bronco 2
2.9
It was a 7.5 out of a ranger
Harley
Oregon
Ford bronco 2
2.9
I didn't see any ratios that ended in 4??
I am not convinced that is the right tag.
alwaysFlOoReD
5,121
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The tags I have seen have the ratio beside the nut, not out in the middle. Also, I don't see any numbers ending in four. I do see a number beginning with four.
Richard
Harley
Oregon
Ford bronco 2
2.9
Weird huh...that was the diff tag...you can see the 7.5 on it...
Are you sure that tag doesn't say 75-140? As in the gear oil spec?
Harley
Oregon
Ford bronco 2
2.9
Not sure...lol...that's why I'm asking, was looking for a rear with 4.10 gears
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I seem to recall having seen two tags on some axles... Is there another tag on it maybe?
Lots of axles have two tags. One IDs the axle, gives the gear ratio, and has what I believe to be a serial number. The other generally specifies the type of lubricant to be used.
rawrrediffer86
Illinois
Look on your door there is an axle code. Like mine is r6 which is the 8.8 with 3.73 limited slip. As a f6 is the 7.5 with 3.73 limited slip.
Sent from my SCH-I545 using Tapatalk
Harley
Oregon
Ford bronco 2
2.9
It was at a junkyard. It did not have a door
rawrrediffer86
Illinois
Oh that makes sense. Was just trying to help.
Harley
Oregon
Ford bronco 2
2.9
I know...thanks.....was looking for a 410 rear
