- Aug 7, 2007
- Reaction score
- 38
- Location
- Farmington, Pa
- Make / Model
- Ford F250 4WD
- Engine Size
- 3.0
- Manual
Normal idle should be around 750-800.
Yours being low explains all the symptoms. Goose the gas, the brownout brightens up.
Fix the idle problem, quit chasing a symptom.
Also not really unusual for the lights to dim at idle when powering the windows.
Try doing it with the gas pedal pressed, increasing idle.
If improved, that confirms idle is low, NOTHING wrong with alternator/battery/charging system..
