My ignition key was stole today.
chessman21
1969 f-600hd
1991 ranger 4.0
My ignition key was stole out of ignition at Dollar General today parked at front doors in my handy capped spot. Had to have it towed home just now, Got thief on video but police arnt to hopeful ill get key back:bawling:,,
Can i get the cylinder out without damaging the cylinder housing or column with a screw driver some how to get it in the "run" position to gain access to push pin? Or do i drill out push pin with cylinder in off position?
91 4.0
Ignition and door key is different.
chewy012
Colorado Springs, CO
4.0 OHV
That is a bummer.
I've got a '92 that turns the ignition switch with out a key (cause it old and busted).
Maybe Jimmy it 'til the mechanism slips?
Sometimes mine catches like it "won't work with out the key" but, a little finess with the steering wheel while knocking the switch gets it where it needs. A narrow flat head should help, as long as your not trying to hammer it into the ignition switch.
Good luck, sorry about your misfortune.
Sent from my XT1254 using Tapatalk
chessman21
1969 f-600hd
1991 ranger 4.0
No its not gonna slip or jimmy, its pretty tight and solid. I know beating a flat head into it sounds kinna dangerous tho.
chewy012
4.0 OHV
Key profile might be tied to the vin #?
Try a Ford dealer?
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Mobile locksmith can make a key for you
Call and tell them location, year and model and they can quote a price
Or you could take out one of the door locks, assuming it used same key, and take that to a locksmith, you would need a title or proof of ownership, most likely.
Only way to change ignition cylinder without the correct key is to drill it out
So weight that cost against mobile locksmith cost
And what other keys were taken?
Was it just the single key in the truck, or were there other keys on the same ring?
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Try a Ford dealer?
Ford keeps those records going back 6 years. GFL with a 91.
Get a pick set or call a lock smith.
Then consider having more than one copy of the ignition key and not leaving the key in the ignition while you leave the vehicle unattended.
chewy012
4.0 OHV
Racing switches?
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
chessman21
1969 f-600hd
1991 ranger 4.0
Solved kinna.
My 1968 f600 hd key went strait in and flipped right over to start. :yahoo:
i was & still are so happy i may need to change my pants again.
I still wanna replace cylinder tho,, feels alotte tighter to turn now, dont see a lock pin hole, all i see is two screws bottom both sides half inch from wheel. Ill figure that out, my oem replacement shows an electrical connector attached to cylinder, anyone know any tips on this one pictured?
AndyB.
142
Cincinnati, OH
You can see the pin in that picture. The wire is resting against it on the far right—it may help you locate it on the lock housing.
RonD
Official TRS AI
8,370
canada
The wire is for "Key left in Ignition" Chime that sounds when driver's door opens
chessman21
1969 f-600hd
1991 ranger 4.0
i see the pin on the new one,, i ment i didnt see the access hole to it on column cover.
chessman21
1969 f-600hd
1991 ranger 4.0
RonD
Official TRS AI
8,370
canada
If you don't have the key, the access to pin hole won't matter, it is only in position when key is in and turned to RUN
I would at least call a mobile locksmith to see what they would charge to make a new key, or TWO, lol.
Because getting out the cylinder "the hard way" can damage the whole mechanism and then you have the cost of that added to the new cylinder cost and you still don't have Door Keys if you ever did want to lock the truck, or accidentally locked it
DIY is great if it saves you time and money, but sometimes it does neither, lol.
Generic pricing for this service here: https://www.247autolocksmith.com/prices
Staff online
Shran
April Truck of The Month
