Would this setup work?
dude772
Caledonia, Ontario
5.0L
Ok, so I've worked myself into a crappy spot. I need to know if this setup would work. I drew it on paint to illistrate it because i dont think i could explaine it.
I dont think i have enough space to be able to mount the third link to the frame and want to know if that would cause any problems?
Then obviously the trac bar would be ther also. Just forgot to add it in.
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Yup, many rigs are built like that. It's just a different form of a radius arm. I'll try and find a few pics....
dude772
Caledonia, Ontario
5.0L
Doing it on just one side isn't an issue?
wahlstrom1
J-man HD Mech
21
Edmonton Alberta
Nope, just make sure it's gusseted properly, and make sure you won't have any clearence issues, particularily exhaust I'm guessing....
-andrew
dude772
Caledonia, Ontario
5.0L
-andrew
hahaha have you been checkin all of my posts from today!?
wahlstrom1
J-man HD Mech
21
Edmonton Alberta
Lol, not intentionally but now that you mention it, I remembered that its you that was having fun with that.....Good luck, your gonna need it! lol
-andrew
rickcdewitt
5
nor-cal
4-0 swap
ah,ok its like wristing one side of a radius arm setup right?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
You'll want to have the link on the diff side if you do that, otherwise the pinion isn't going to follow the driveshaft too well (possibly binding the u-joint).
Also, I would have the links directly above one another on the axle with that setup, not offset like that.
dude772
Caledonia, Ontario
5.0L
Any suggestions on what size joints to use for that?
JohnnyU
"Outlaw"
8
Chillicothe, Illinois
Chevrolet
Ls2
I think he was referring to flex joints. I wouldn't use anything less than a 2.625" Johnny Joint, or similar.
dude772
Caledonia, Ontario
5.0L
i mean for the small link not the long links
Toreadorranger
5
Sal
the difference is negligable on which side the upper link is on. Some guys run them on the diff side and it works and others run them on the tube side and it works just the same.
