Woody's SAS Build
WoodyB2
Vancouver,WA
Picked up the axle, needs some work but the gears and locker look great. Ordered a new diff cover as this one was the ugliest self made one ever.
WoodyB2
Vancouver,WA
So picked up new ball joints and carrier bushings, might as well while its out and torn apart.
Also my diff cover showed up today, this thing is beefy!
WoodyB2
Vancouver,WA
WoodyB2
Vancouver,WA
Cut off all the useless crap from the previous owner...
His "truss" was super useful!
WoodyB2
Vancouver,WA
Swapped the carrier bearings today and cleaned and painted the axle.
But found an issue install the diff cover, one of the bolt holes is stripped...so I need to install a helicoil or get it fixed somehow.
Grunizzle
01/2013 OTOTM Winner
U.S. Military - Active
Albuquerque, NM
4.0L V-6
Looking good Jeff! Let's see some more pics of the truck out camping and wheeling!
When are you getting the rest of the SAS stuff?
WoodyB2
Vancouver,WA
Soon, thinking in a month or so. Working the second job that I do every year, so wont have time until the end of the year. I am still in the collecting stage.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
looks good dude, I had missed this somehow. I did a D30 swap on my b2. it's still in the tinkering phase. lots of pics in my build thread
WoodyB2
Vancouver,WA
Thanks man.
I had totally forgotten you started that around the time I sold my bronco. Ill have to check it out!
WoodyB2
Vancouver,WA
Grabbed some shafts from pick n pull half off sale.
Found a nice disk brake 8.8 but that thing was giving me major crap while pulling it so I walked away
WoodyB2
Vancouver,WA
Ok so I have the front planned out as far as lift goes. Running 5.5" rubicon express Cherokee coils.
But I still am undecided on the rear. If I use shackles and exploer or Chevy leafs I'll still need to run the factory block to get the height I want... I really don't want to run a block.
That leaves me with what? Lift springs? If so what are some good ones?
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
You can get a "add a leaf" I used a 2" lift aal under my truck for several years. They were like 200 I think brand new.
YooperSteeze
Da UP, eh?
5.0/4.0/4.0
Could also lower your mounting points on the frame, as in drop your shackle hanger so the top two holes on the hanger use the bottom two holes on the frame, and take some angle and bolt it to the frame and drill holes for the bottom two, should net you a couple inches of lift. Or if you want to get real crazy, inboard your leaves, as in mount them under the frame. Gives you lift, and more flex because the tires have more leverage.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
I like the idea of moving them inboard. That would net you several inches more but it would increase body roll. Also it would be a good idea to box the frame at each hanger.
WoodyB2
Vancouver,WA
Moving the springs inboard is not a bad idea, but how much would it effect the daily drivability as well as towing with the truck?
