polar765
- Nov 5, 2010
- 0
- Ford
I recently swapped a 94 mazda 4.0 into a 93 ranger ,which also had a 4.0 ,also used the 94 autotrans ,we changed the engine wireing ,the plenum ,the sensors from the 93 ,replaced the 94 egr exhaust with the 93 exhaust ,new o2 sensors ,did a fuel pressure check with a guage ,replaced the coil pack to the 93 ,so everything is now 93 ,the engine starts instantly and idles then goes through a rough idle but then smooths out and is driveable ,seems low on power ,once the engine is warm it will not start ,it cranks ,the fuel pressure is 35 lbs and there is spark ,starting fluid doesn't help ,once it cools off its starts again ,have tried both temp sensors ,both maf ,both idle control modules ,throttle position sensors with the same out come ,there are not any codes in the computer even after driving for about a half hour
