Won't rev past 4k
Haywire6000
Lewiston Maine
1997
2.3 Turbo Four Plug Head
So just curious, my Dad has a 94 Ranger 4.0 Auto. No matter what you do it will not rev past 4000 in gear, even to the carpet from and stand still and going through the gears. Just wondering if any one else has seen this or if this is even normal.
Denisefwd93
74
South East PA
May be Gas cable stretch
Haywire6000
Lewiston Maine
1997
Checked it she's getting wide open throttle, TPS voltage is correct and everything thing else looks good. I just find it weird...
8,372
Couple of things
Yes, Google: Ranger throttle cable Mod
Simple fix when you loose full throttle
Neutral switch(NSS) on transmission.
The shifter on transmission must be in Park or Neutral for starter motor to work, this is done via the NSS, this switch also does Reverse lights, just FYI
When trans is in Park or Neutral the Computer ALSO gets this signal, this enables the REV Limiter, prevents over REVing when NOT in gear.
If some one BY-PASSED this switch, to get starter to work, then computer thinks transmission is ALWAYS in Park or Neutral :)
So you always have REV Limiter ON
Look here: http://www.auto-diagnostics.info/ford_eec_iv
Check out pin 30, Neutral 0V-0.1V, In gear 5Volts
gw33gp
538
Costa Mesa, CA
4.0 SOHC
33"
Just curious, why do you want to take a 4.0 OHV engine past 4,000 rpm? Horsepower and torque should be beyond peak at that point. Time to shift.
Haywire6000
Lewiston Maine
1997
It's not that I want to rev it any higher, it's just like I said I find it weird the ECU doesn't let it rev higher in gear. 4k for a gas( Even for being a push rod engine) seems low.
6
USA
3.slow
To each his own.
Love my high revving 3.slow. It will max out the tach if I want (6K) except in park or neutral, then it's 3K. Can't seem to hurt the old bitch. Speed limiter at 91 MPH, but why should I care ? I never go faster than 74, except during an occasional Italian Tune-Up LOL
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
there certainly are times to rev a 4.0 past 4k.
and you have to when it is one of those times.
bad switch will do it though.
on edit....if its running out of fuel from bad pump or filter it will do that too.
