- Oct 26, 2007
- 3
- Age
- 37
- St. Louisville, OH
- Ford
- Engine Size
- 4.0
My first truck was an 88 toyota 4x4 5speed with the 22re. But my first truck that was actually mine was a 99 ranger 4.0 5speed 4x4. This is the history of my 99 and how i kind of fell into a project.
Started off stock with 110,000 miles on it.
Body lift and 33 12.50 Buckshots
2 inch blocks torsion crank 33 12.50 wildcat all terrains
Guy ran a red light and t-boned me. Ran over them and flipped on my side. Totalled
This is when the solid axle swap was decided on. I got a set of dana 44s off of an 89 Grand Wagoneer. Started cutting and havent stopped for about 7 months straight. Progress is slow but I figured I would put what Ive got done so far and add to it later. Any advice or comments are welcomed.
Because it was totalled I had to get it running so I could get a salvage title which was a joke. Advice for people doing a rebuild DONT DO TOO MUCH! The least amount you have to do to get it driving the better. The only things they check are vin numbers on body parts and any major components ex. engine, trans, etc. Some stuff I did to get it going after the wreck.
Rhino lined floor
replaced doors
and fender
The dana 44s
cutting
Nissan box Prolly gonna use a toyota box if I can find one, but this is all the yard had at the time.
My tires and rims Im going with. 15/38.5/15 boggers on 15x10 aluminum
Got a lot more but need to figure out the best way to load pics on here. Should have my 6 inch superlift chevy springs for the front any day now and already have everything for the 63 inch chevy swap in the rear. Have crossmember welded on and hope to have the pinion angle set and the front sitting on its own in a couple weeks. Wanted it to be done for my wedding on june 20th but its not lookin good. Oh well let me know what you think and i will try to update it as much as possible.
Rhino lined floor
replaced doors
and fender
The dana 44s
cutting
