Wipers malfunctioning
rg2200
I just picked up a 2005 Ranger Edge 2WD. On the intermittent wiper settings, the wipers move a few inches, pause, then move a few inches, pause etc. On Low and High, they function, but don't return to the cowl when you turn them off (you have to turn them off just before they get to the bottom position or they just stay where they were when you shut them off.)
Question - is this likely the wiper motor, or the multifunction switch? I have a 1990 Ford Probe and had a somewhat similar problem (wouldn't work on high, wouldn't return to the cowl properly) and replacing the wiper motor fixed it, but I don't want to buy a new motor if it's the switch - hoping somebody here has experienced this and knows which part I need to replace.
Schnot
Ringtown, PA
2.9L
I have the same problem on my 2001 f350. On those, the windshield is known to leak and run down onto the gem module and fuse box. It corrodes and causes all sorts of problems. I know for sure it's the gem because I've changed everything else.
On my 89 ranger it was a bad ground on the wiper motor.
For yours I'd start with the switch. Check the local junkyards or used ones on eBay before you dump too much money into an unknown problem.
Sent from my iPhone.
rg2200
I've checked out eBay and found a switch for $50, and a motor for $58. I'll try the pick a part this weekend and see what I can find.
What's the GEM?
It seems to be more likely to be the motor than the switch because I'm not getting any of the 'phantom wiper' issues that I've seen in the forum from other people - they don't turn on on their own, and when they're on they work consistently - only when on intermittent they just move a few inches, pause, then move a few inches and the length of the pause varies with the intermittent setting. This makes me think that the switch is sending the signal to the wiper motor and it's just not responding correctly. I might just take apart the wiper motor and clean the contacts etc. After buying a new wiper motor for the Probe, I took apart the old one and cleaned it up and it seemed to work after that (should have done that originally, but didn't want to be without the wipers if the wiper motor repair made things worse...)
I'll check the ground - they're notorious for problems (the automated seatbelts in my Probe wouldn't work, so I retightened the ground on the inertia switch (fuel cut-off) in the trunk, and that fixed the seatbelts. I also had various issues with grounds on my 1993 B2200 (that I put a 5.0L v8 into with a megasquirt DIY engine management computer) - I traded the 93 B2200 for the 2005 Ranger just a few weeks ago.
Schnot
Ringtown, PA
2.9L
Gem is the general electronic module. It basically controls everything in the truck. How long the light stays on, how often the wipers wipe, sends power to the t case, etc. Older vehicles dont have them, but most newer ones do. I don't know if they can be a problem in rangers but I figured I'd offer up my experience with them.
rg2200
I'm assuming the GEM is different than the PCM (Powertrain Control Module) (sometimes called an ECM or ECU)? I'll do some searches to see where it's located on my Ranger.
Schnot
Ringtown, PA
2.9L
Correct. PCM controls the power train. Hence the name.
rg2200
So, last night I took out the wiper motor (that's quite a job, surprisingly) and took it apart and cleaned it up and sprayed some electrical contact spray on all the elec contacts. I noticed that one of the 3 brushes had the end broken off and was only just barely contacting the commutator - I can't say I've worked on a lot of electrical motors, but I'm used to only seeing 2 brushes - I wonder if the third brush is to do with the wiper return (power to the 3rd wire runs the motor until the wiper returns to the normal position)?
I haven't had a chance to search for the GEM yet - if anybody knows off the top of their head where it is in a 2005 Ranger, let me know, otherwise I can do some searching.
rg2200
I did a little searching on the forum and found this thread: http://www.therangerstation.com/forums/showthread.php?t=36624
"I thought the 05+ didn't have GEM modules anymore. But I could be wrong..."
Can anybody confirm whether the 05+ have the GEM module or not? If my 2005 doesn't have it, then that narrows down the problem to the wiper motor or the combination switch.
rg2200
So, I went to the auto wreckers today and picked up a wiper motor off a '99 for $40, put it in and the wiper problem is fixed.
