Wilson 1000 or 2000?
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
Finally going to bite the bullet and get this thing working. I've narrowed it down to two options:
The antenna will be mounted behind the cab on a toolbox.
The Wilson 1000,
Base mount, so the coil is under the roof :mad:
Removable coil base so i can use the car wash :D
No rear visibility problems :D
Won't block 3rd brake light :D
Signal will be partly blocked by cab :mad:
The Wilson 2000,
Mid Mount, 18" long 3/8" stand will put coil just over top of roof :D
Removability issues? :mad:
Shaft might block view, window seam does anyways? :icon_confused:
Will partially block out 3rd brake light :mad:
leverage might bend up my nice new tool box or damage something else? :mad::mad::mad:
Signal completely unobstructed by cab :D:D:D
Thoughts? Experiences?
Earl43P
38
Farmington, Pa
Ford F250 4WD
The Wilson 1000,
I have experience with that set-up. Mine squeeled every time I keyed the Mic. I stuck it to the aft cab roof and it worked great, but trees tended to knock it over in the woods, which is where I primarily used it (hunt club)
The Wilson 2000,
I think this setup will squeel too. I don't think having the coil midway up is going to give you an unobstucted signal like you think it will. I ended up using a different Wilson, but I can't recall its model name/#. Smaller magnetic base and smaller coil, like the 1000, but half the height. It worked "ok" when stuck on the cab roof.
BisketFx4
Florida
Have you thought about a firestik
Captain Ledd
39
Michigan
302, 2.3
Well the 2000 seems like a normal Wilson just mounted on a post. The post doesn't do any of the transmitting or receiving.
I'm really not too keen on a roof mount of any type. Absolutely no holes are going to be drilled in my roof, nor do I feel like having a cable hanging around.
Have one on Deathtrap. Too stiff and I want something a little more slender for the highway driven Ranger.
02RangerXLT
53
NE
Get the 2000, a 3/8" rod isn't going to obstruct your vision any more than a bar on a sliding rear window equipped pickup. It won't block the third brake light worth a crap either... the block would be negligible. Also, Shouldn't bend it. Just get a "heavy duty" stud for it... should be larger than a normal stud.
No members online now.
