Will this work
kevinbmx77
Can i put these on my 1994 2wd the way it is?
They're 6 inch lift springs
kevinbmx77
What else would i have to do to make these work right? How do i extened the radius arms?
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
You'd have to get drop brackets for the radius arms and beams then figure out a lift for the rear end.
kevinbmx77
I have 3 inch blocks for the rear and my front is already about an inch or two lower. The front should sit alittle higher which i dont mind because im going for the whole prerunner thing soon
kevinbmx77
And thank you for the answers [emoji2]
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
There are several threads on extending radius arms. Read up on them then decide how you want to extend your radius arms.
If you can find the beam brackets then you could build radius arms and radius arm brackets to match. Just search it and read all the threads you can to get a understanding for how everything works.
kevinbmx77
Where would i get beam brackets or even find them? When i search on google for them it comes up with the radius arm brackets instead. I search "ford ranger i-beam drop bracket" "ford ranger i-beam extension
No members online now.
