Will these aftermarket jeep rims fit my ranger 4x4
mr_speed77
I have a 93 4.0 4x4 and was looking at some american racing AR-767 rims that came off a 89 wrangler. they have 31's on them and i believe they are 10 wide. no clue on backspacing though? any help?
dangeranger01
Longview, WA
3.0L
The bolt pattern will be right, the only thing you would have to look for would be if the hole in the center is big enough to go over the hub.
mr_speed77
I believe they are 15x10 with -38 offset and 4 backside. Think they will work?
wvcat
The wheels on one of my trucks came off a jeep. There are american wheels. They would probably work.
John
racsan
4,495
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
my winter rims are stock steel rims from a jeep and fit o.k. no center hub issues at all, just had to cut out the plastic center cap for the lockouts.
________
digital vaporizers
bikerboy
Lancaster,PA
the jeep wheel should fit fine. the hubs should be good. ford hubs are smaller than jeep hubs. you'll be good to go. these are my wheels off a 91 Cherokee
98ranger4x4
Las Vegas, NV
as long as they fit over the hubs you will be fine. a -38 15x10 will stick outside the fenders a ways, might cause clearance problems on fender wells when turning. other than you should be good to go!
ADRIANL82
2003 Ranger Edg
Jeep Canyon tires
I have a 2003 Ranger Edge 4X2. I have a chance to buy the jeep canyon tires which I think will look great on the truck. Problem is the front hub, will it fit through the hole and if it does how much of the hub will stick out past the rim face.
