gertsdsbs
- Sep 13, 2008
- 0
- On the Moon
- Ford
- Engine Size
- 2.9 v6
so i've decided to get this amp
Rated Power: 250 Watts x 2 (2 ohm); 500 Watts x 1 (4 Ohm Bridged)
High-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
MOSFET power supply
Speaker-level inputs with signal sensing turn-on
One-year limited warranty
Technical Details
Audio Section
Max Power Output: 1000 W (500 W x 2)
Rated Power Output (+B = 14.4 V): Normal (4 Ohms) (20 Hz - 20 kHz, 0.08 % THD) 170 W x 2; Normal (4 Ohms) (DIN : 45324, +B = 14.4V) 170 W x 2; Normal (2 Ohms) (1 kHz, 0.8 % THD) 250 W x 2; Bridged (4 Ohms) (1 kHz, 0.8 % THD) 500 W x 1
Frequency Response (+0, -3 dB): 5 Hz - 50 kHz
Sensitivity (rated output): 0.2 V - 5.0 V
Input Impedance: 10 kOhms
Signal to Noise Ratio: 100 dB
Low Pass Filter Frequency (-24 dB/oct.): 50 - 200 Hz (variable)
High Pass Filter Frequency (-12 dB/oct.): 50 - 200 Hz (variable)
Bass Boost Circuit (40 Hz): 0 - +18 dB (variable)
General
Operating Voltage: 14.4 V (11 - 16 V allowable)
Current Consumption: 40 A
Installation Size (W x H x D): 350 x 59 x 238 mm (13-3/4 x 2-5/16 x 9-3/8 inch)
Weight: 3.2 kg (7.0 lbs)
10" 2-ohm subwoofer
injection-molded polypropylene woofer cone with ribbed Santoprene surround
power handling: 50-400 watts RMS (800 watts peak power)
frequency response: 25-350 Hz
warranty: 1 year
SO WILL THIS BE A BIG DIFFERENCE IS IT A GOOD SET-UP? THANKS.
MOSFET power supply
Technical Details
Audio Section
General
10" 2-ohm subwoofer
warranty: 1 year
