Will a Holley sniper work with a 1985 A4LD?
MDK231
Pittsburgh
Ford Bronco 2
Will a Holley sniper work with a 1985 A4LD? Looking at a 1985 bronco 2 for sale locally with a 2.8l and an A4LD. Anyone have any experience putting a sniper on a 2.8?
Junk Collector
Truck of Month
4,849
Rapid City SD
Do it.
Kickdown rod may be an issue, that’s the only major thing I can think of and it’s a very minor thing overall.
rusty ol ranger
2.9 Mafia-Don
7,605
Michigan
177 CID
Do it.
I think you would have to wire the converter lockup to a switch.
Junk Collector
Truck of Month
4,849
Rapid City SD
Yeah, disregard what I said about the kickdown. I had C5s on my mind for some reason. You are correct.
MDK231
Pittsburgh
Ford Bronco 2
I'm wondering if I can somehow use the Holley sniper to control the transmission. What does the stock computer look for to lock the converter? I believe the early A4LD is all hydrologic other than the converter? This would be my first ever project car and I have a lot to learn here.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Just needs a psi switch. Sniper don't run a transmission.
