Wideband O2 wiring
xsaylr
20
b0bber!!
Like to add a wideband and AFR gauge, but I'm unsure how to connect it to the factory ECU. Haven't been able to find anything explaining how to wire one in. '97 2.3, adding a turbo and just about ready to test.
8,372
You don't or can't use wide band O2 with older Computers, they can't read them
You would add another O2 bung to exhaust pipe for the wide band O2 to hook up to the AFR gauge
You can get clamp on O2 sensor bungs, but an exhaust shop can weld one on pretty fast and doesn't/shouldn't cost that much
Google: Clamp on O2 sensor bung
Should be near upstream O2 but 3-4" away and 90deg to 120deg offset so exhaust flow wake from front O2 doesn't interfere
kodogtwh
61
North Carolina
You can't use a wideband with eec-V. You need to use an aftermarket gauge and tune with that.
Are you really using a stock ECU to turbo your truck? Sounds like trouble to me. A microsquirt is $350.
xsaylr
20
b0bber!!
Yep got the gauge in at this point. Yeah I'm familiar w/Megasquirt, use that on an SVO. Guys in the turbo Ranger facebook group suggested keeping the OBD2, and I'll be using I think it's called SCT's Pro Racer app, along with the SCT handheld, for tuning. Truck's actually been done/ready for 2 weeks now, but it wasn't til after that that I found out I'll need this app. Already had the handheld device. We'll see how it goes
