Who is using the 2 piece extended Brake line
Broncojumper87
U.S. Military - Active
12
wichita Kansas
2.3 EcoBoost
Just wondering who is using the 2 piece brake line from the tech section? How reliable is it and what are your thoughts on it?
4.0B2
151
Walls, MS
4.0 v6
I used it for awhile. Worked fine for me.
Later I redesigned my entire front brake line setup.. not b/c the other method didn't work... I just needed a little more travel.
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
That's what I wanted to hear just to make sure I read it right I will need 2 lines from each list with 4 lines total? One last question this will work on my 87 b2 right?
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
It is working for me right now.
4.0B2
151
Walls, MS
4.0 v6
Yes and Yes..
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
With the extra length how do you guys keep the line in place or do you just lt flop around?
4.0B2
151
Walls, MS
4.0 v6
I tied the center "hard" piece to the coil... just left slack above and below it.
Harley
Oregon
Ford bronco 2
5.5 in susp 2 in body
can i just get the extension to add to my stock line?
4.0B2
151
Walls, MS
4.0 v6
I think the ends at the middle are different. You can try it though
Harley
Oregon
Ford bronco 2
